My neighbor has problems with his solar system. I had my meter on his solar and about every 1/2 hr there will be a surge of voltage going up from 10v to 30vs. It will kick out the 60a breaker ever so often but in no order of time, but nothing else. The amps seem to remain steady. There is a small fluxuatin in the battery voltage when in float but the batteries test out ok. I think he has a bad cable somewhere in his system. any ideas? 24v system 1200 ah bank lead acid 2 Midnite controlers. There are 2 seperate solar panels some 40 ft apart. they all feed to one piont. 6 250 w 24v panels on one set , 6 - 180w 24v one the other set of panels. ?? 13
