Author Topic: Bearings used on top and bottom of assembly  (Read 1869 times)
Yianie123.
« on: June 09, 2014, 10:50:52 PM »
I know that most wind turbines are mounted on 2 inch pipe, but what type of bearings for rotation are used to rotate the entire assembly (not the blades).  Is it just a capped outer pipe outside another pipe with a brass washer( Flat round bushing )?  Pictures will be greatly appreciated.
Yianie123.
Re: Bearings used on top and bottom of assembly
« Reply #1 on: June 12, 2014, 10:30:55 PM »
I will use bronze bushings instead.
kitestrings
« Reply #2 on: June 13, 2014, 05:49:43 PM »
Y,
We used a bronze graphite thrust washer sandwiched between two flange washers.
Yianie123.
« Reply #3 on: June 18, 2014, 07:27:13 PM »
Thank you for your reply.  I'm greatful.  What size pipe did you use and do you have a part number for your bushing?
Thank you, John
