Author Topic: 7 KW WİND TURBİNE  (Read 11266 times)
atasan2006
  • Country: tr
  • The modest türbinc
7 KW WİND TURBİNE
« on: November 24, 2015, 12:55:18 PM »
hello friends I retired 51 years old and I live in turkey green energy as an amateur I deal I made 7 kW turbine   https://youtu.be/-RRAeTKTcdA https://youtu.be/TvEiz_Uc1IQ
Learn teach you knew you did not know
Re: 7 KW WİND TURBİNE
« Reply #1 on: November 24, 2015, 01:57:54 PM »
Welcome to the forum
 Very nice 'mill!! Could you tell us more about it?
atasan2006
  • Country: tr
« Reply #2 on: November 24, 2015, 02:04:39 PM »
How do I install hi Bruce could not upload images to the forum
atasan2006
  • Country: tr
« Reply #3 on: November 24, 2015, 02:52:09 PM »
deneme
« Reply #4 on: November 24, 2015, 02:54:44 PM »
I see you found out how to post pics.
Very nice.
There really isn't an easy way to "ADD" pics to posts already here for more than 30 mins.
You can modify your own posts for that short of a time line , but that is about it.
Most merely make another posting with the pics
Best Regards;
atasan2006
  • Country: tr
« Reply #5 on: November 24, 2015, 03:31:38 PM »
off the grid that if the system will talk about the features of cordless hybrid bi system tower height of 16 meters wing length of 480 cm total diameter of 9.60 cm alternator stator 8 cm derinlikd 84 well 10 from 0.90 wire 1.35 2 16 spin hugged rotoru28 kutpl ie two magnets üstüsd used was 112 adetd in the system total Do not miss the tail are also available in the centrifugal pitch
atasan2006
  • Country: tr
« Reply #6 on: November 24, 2015, 04:00:26 PM »
manufacturing te some pictures
atasan2006
  • Country: tr
« Reply #7 on: November 24, 2015, 04:07:16 PM »
Some examples
atasan2006
  • Country: tr
« Reply #8 on: November 24, 2015, 04:15:04 PM »
more blade length of 4.70 cm diameter 9.40 cm leaf weight 19 kg
« Last Edit: November 24, 2015, 04:21:35 PM by atasan2006 »
atasan2006
  • Country: tr
« Reply #9 on: November 24, 2015, 04:16:07 PM »
more
atasan2006
  • Country: tr
« Reply #10 on: November 24, 2015, 04:17:53 PM »
tower 16 meters
« Last Edit: November 24, 2015, 04:23:57 PM by atasan2006 »
atasan2006
  • Country: tr
« Reply #11 on: November 24, 2015, 04:27:04 PM »
alternator The 8 cm depth in 84-well alternator stator wire 10x 0.90 2 x 1:35 spur hugged rotoru28 üstüsd kutpl ie two magnets were used in a total of 112 piece
« Last Edit: November 24, 2015, 04:34:48 PM by atasan2006 »
atasan2006
  • Country: tr
« Reply #12 on: November 24, 2015, 04:37:14 PM »
alternator rotor
« Last Edit: November 24, 2015, 04:41:24 PM by atasan2006 »
midwoud1
« Reply #13 on: November 25, 2015, 04:58:01 AM »
Hi Atasan
Welcome . Nice windmill project. Text is a bit difficult to read .
Like to know more about it . Blade pitch system, Storm save ,Output figures ,  Use of power, Average windspeed , Tower angle iron size and fundation ,Generator specs . I see you are good in several disciplines.
 Regards  Frans .. Midwoud1 , Netherlands.
« Last Edit: November 25, 2015, 05:03:28 AM by midwoud1 »
« Reply #14 on: November 25, 2015, 08:17:40 AM »
Welcome Atasan,
Nice looking turbine.  Please tell us more, as Frans described, when you can.  Best, ~ks
atasan2006
  • Country: tr
« Reply #15 on: November 25, 2015, 10:30:33 AM »
Hi Atasan
   hello midwoud1 bad I'm so sorry for english bladees root 20 degrees end there are 4 degrees centrifugal pitch system and furling turbines 42 d.d rpm for 70 DC volts produces 3 & 100 amps are within the basic tower core 60mmx60mm thickness of 0.8 mm tower 60mmx 60mm thickness 0.6mm cross 0.5mm thick pieces 50mmx0.5mm
« Last Edit: November 25, 2015, 10:40:20 AM by atasan2006 »
atasan2006
  • Country: tr
« Reply #16 on: November 25, 2015, 11:11:28 AM »
tower size
« Reply #17 on: November 28, 2015, 02:00:46 PM »
Nice  rotor and rewire....looks like a nice compact high  output gen...how's it on heat dissipation  ?
« Reply #18 on: December 03, 2015, 04:15:36 PM »
Awesome project, love the build photos and details.  rich
midwoud1
« Reply #19 on: December 03, 2015, 05:09:54 PM »
@ Atasan.
Please more info (Photo, drawing )about the pitch controlled blades , It looks they are in a feathered position.
Regards : Fbm
atasan2006
  • Country: tr
« Reply #20 on: December 05, 2015, 03:58:07 PM »
very sorry to colleagues drawings
midwoud1
« Reply #21 on: December 05, 2015, 04:36:54 PM »
Hi Atasan
Tail furling connected  blade pitch control.
That is a bright idea , I work many years with variable blades, but never seen this before.
Looks simple and effective , hope it works well.
Keep us informed ,
Regards  Fbm . Midwoud1
mbouwer
« Reply #22 on: December 06, 2015, 12:46:54 PM »
To Atasan2006
Nice windmill,
Might be an idea to improve your pitch regulation: https://www.youtube.com/watch?v=rUcxmbLfu_U
Regards Rinus
atasan2006
  • Country: tr
« Reply #23 on: December 06, 2015, 12:59:25 PM »
Hi mbouwer will need electronic circuit to control the pitch I watched this video I'm looking for a simple system
