Author Topic: Pendulum Turbine  (Read 3185 times)
Rover
Pendulum Turbine
« on: November 12, 2009, 10:42:25 AM »
This works by swinging one way then back
My little GE ECM turbine survived the current North Easter, but the blades on this one didn't
« Last Edit: November 12, 2009, 10:42:25 AM by (unknown) »
Rover
Rover
Re: Pendulum Turbine
« Reply #1 on: November 12, 2009, 11:59:06 AM »
Adding.. just found one blade 80 ft away in front of my house, still attached to part of the 3 arm rotor . 5/16 " steel snapped. At least it wasn't my bolting
« Last Edit: November 12, 2009, 11:59:06 AM by Rover »
Rover
mixerman
« Reply #2 on: November 12, 2009, 02:41:12 PM »
What caused this? What would you do differently? Any before pictures of the hub?
« Last Edit: November 12, 2009, 02:41:12 PM by mixerman »
Rover
« Reply #3 on: November 12, 2009, 03:01:36 PM »
Yep, gonna have a new hub cnc'd.... specs I'll determine after studying it. Deal is that was a commercial cast hub that should not have given way after 2 years.
« Last Edit: November 12, 2009, 03:01:36 PM by Rover »
Rover
scoraigwind
    • www.scoraigwind.co.uk
« Reply #4 on: November 15, 2009, 03:08:47 PM »
You could try putting it up above the tree tops in clean air.  Turbulence will accelerate failure of the hub.  Cheap chinese stuff usually sheds blades sooner or later, but sooner in a rough site.
« Last Edit: November 15, 2009, 03:08:47 PM by scoraigwind »
Rover
« Reply #5 on: November 16, 2009, 03:16:06 AM »
That would be best but unfortunately I can't raise it any higher, 30 ft is the max I can get away without runing afoul of the authorities.
« Last Edit: November 16, 2009, 03:16:06 AM by Rover »
Rover
RedJoker
« Reply #6 on: November 17, 2009, 04:13:06 AM »
I'm in the same boat.  I just shake my head everytime I see all the trees around.  Luckily, I'm still producing more than I'm using in that application.
« Last Edit: November 17, 2009, 04:13:06 AM by RedJoker »
Rover
« Reply #7 on: April 02, 2016, 04:23:15 PM »
I did construct a new hub using 1" thick x 8" diameter aluminum, balanced for the blades. The blades were my construction out of layed up vacuum  fiber glass, and this unit is still running
Rover
Blast from the past
Rover
« Reply #8 on: April 03, 2016, 08:35:58 PM »
Welcome back Rover!
