Remote Living > Transportation
Curtis 1208C Component Question
RndmGuy06:
--- Quote from: mab on September 02, 2016, 05:15:46 PM ---This is a pure guesswork, but if you replaced TH1 with the jumper, then it may be that TH1 was a negative temp coeficient thermistor (resistance goes down as temp goes up) which derates the controller as the temperature goes up. by replacing with a straight wire you're making the controller 'think' it's very hot, so it's limiting the current.
trouble is, guessing what sort of NTC thermisitor is needed.
--- End quote ---
That makes the most sense. Thank you for the suggestion. I have an extra 5k pot. Sounds like a good place to start.
I'll try it in the morning.
Navigation
[0] Message Index
[*] Previous page
Go to full version
