Remote Living > Housing
Garage Door Opener Inverter Asleep.
Mary B:
Use a 5 volt motion sensor with a 5 volt regulator board in front of it for a stable voltage. Then use a 5 volt relay with contacts that can handle your load. Or 12 volt and same setup
https://www.ebay.com/itm/LM317-DC-DC-1-5A-1-2-37V-Adjustable-Power-Supply-Board-DC-Converter-Buck-Step-B3/123258246168?epid=26021558167&hash=item1cb2c39418%3Ai%3A123258246168&_sacat=0&_nkw=adjustable+voltage+regulator+board&_from=R40&rt=nc&_trksid=m570.l1313
armadillo:
Thanks for the replies. I ordered some 1N4004 diodes from ebay. Using the openers brain is over my head. I already have the 24 volt motion sensor and a relay with a 24 volt coil so I'll continue to pursue that route.
Navigation
[0] Message Index
[*] Previous page
Go to full version
