Thanks for this Adriaan. It's helpful to me better understand the variables. Can you expand on one thing for me, that is to describe a bit more the Reynolds number. Broadly I understand that larger diameter turbines have higher Reynolds, therefore lower drag, and I assume a more efficient transfer of power. The fluid, the air in this case doesn't change though, so what are the factors that influence the Reynolds number. Is it only the profile and chord thickness of the airfoil, or do things like the surface smoothness effect Reynolds?
And related, I've read portions of KD 35, I'm confused by the units for Reynolds. It's in the range of 5 x 10^5 for a small turbine, but in in the definitions it shows (-). I'd thought somehow this just meant the result was a negative number, but I notice for example the number of blades it is also (-), so perhaps this has another meaning.
Mbouwer, looking at the floating 2-rotor design, I assume there could be some additional torsion loads, and possibly vibration/harmonics introduced?
~ks
