Part II of the Biolite combo
The grill section is made of 3 parts, along with a stainless steel cap that closes over the chimney fire to push the fire towards the grates.
The main outside part is stainless steel , however , it is magnetic enough to hold onto even a ceramic magnet.
The inside is a flame defusser, or grate .
The top part is the standard cooking grate.
There is also two pop out legs. We loaded up 5 Brats and a small pot of veggies and it help up pretty well.
The combo came with their kettle too, it holds 1 1/2 liters of liquid with air holes around the rim so it can sit directly over the flame chimney.
My biggest pet peeve is that you cannot stack them both on top of the fire at the same time. I'll be finding a solution to this
![Smiley :)](https://www.fieldlines.com/Smileys/default/smiley.gif)
When using it for a long term fire; a little attention is needed to not plug the gas vents at the bottom.
All-in-all, not a bad setup. For an avid hiker/camper/kayaker , this isn't too pricey.
The fact that you can charge your cell phone, boil up liquids and have fire. It's okay
I'd would like it better if I could to grill, boil, charge my batteries and have a small flame.
I'm still learning how to best use this, so if you have any questions, fire away.
