Author Topic: Report KD 669 about VIRYA-1.75W rotor available  (Read 1048 times)
Adriaan Kragten
« on: December 29, 2018, 10:11:39 AM »
Report KD 669 can be copied for free from my website: www.kdwindturbines.nl at the menu KD-reports. The title of this report is: "Calculations executed for the 2-bladed rotor of the VIRYA-1.75W windmill (lambda design = 7, wooden blades) with a Chinese axial flux generator of Hefei Top Grand model TGET165-0.15KD-500R used for 12 V battery charging". This generator has been tested for some years in combination with the VIRYA-1.65 rotor with cambered stainless steel blades but this rotor appeared to be too noisy. It is expected that the VIRYA-1.75W rotor with wooden blades will be more silent and that the maximum power is higher because of the larger rotor diameter.
KD 669 contains detailed technical drawings of the rotor and the generator bracket. The head and tower of the VIRYA-1.81 can be used. Photos of the drawings of head and tower are given in the manual part 2 of the VIRYA-1.81 which can be copied from my website. To give an impression of the rotor, I have added the assembly drawing with drawing number 1802-01 as an attachment.
The big advantage of the VIRYA-1.75W is that no generator has to be built. The used generator has been measured (see report KD 595) and can be ordered directly in China. The generator is of type axial flux but the housing is completely closed.
Adriaan Kragten
Re: Report KD 669 about VIRYA-1.75W rotor available
« Reply #1 on: December 31, 2018, 08:14:00 AM »
A folder about the VIRYA-1.75W and the VIRYA-1.8W is added to my website at the menu VIRYA-folders.
Adriaan Kragten
« Reply #2 on: January 04, 2019, 05:36:07 AM »
My website has been made safer by changing to: https://www.kdwindturbines.nl. This has been done by using the plugin Really Simple SSL.
