Remote Living > Lighting
Here is a night light project
SparWeb:
Ed,
I'm really intrigued by your idea. I've also been thinking of ways to make it simpler/cheaper.
How does this look to you?
SparWeb:
Clicked "submit" too quickly...
The resistors do the step-down. The capacitor is optional but may reduce the blinking. The diode in series with the LED is not crucial, but I don't trust a LED alone with 120VAC. The fuse is not shown in the circuit but I think it's a VERY good idea to have them.
SparWeb:
Here's another.
I eliminated the capacitor. I shouldn't have done that. I also added a fuse instead.
If you want to try something cool, go to this site: http://www.falstad.com/circuit/
...and load this file:
circuit-20190331-1914.circuitjs.txt (0.33 kB - downloaded 295 times.)
MagnetJuice:
That last circuit that you posted works OK. You might need to increase or decrease the resistance to get the right brightness depending which LED you use. The LED flicker will be worse with the single diode because you will only get half the wave from the AC sine wave.
There is not big savings by substituting the bridge rectifier with a single diode.
3 cents for the diode or 8 for the bridge. Five cents savings.
With 5 cents and $1.75 you can get a black coffee at Starbucks :D
SparWeb:
I don't know how I misled myself, but I thought you were using a bridge the size of a scrabble tile.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
