To try to answer the original question, we need to consider how a hollow sphere would be made and magnetized. Where would the poles be?
I see two theoretical possibilities of constructing this spherical magnet:
1 – We start with a flat magnet that has the poles like this:
If we fold this flat magnet into a sphere we end up with a sphere that has one pole on the outside surface and the opposite pole on the inside surface. Like this:
This is interesting because if we place a smaller hollow sphere with opposite polarity inside this sphere, the small sphere will be suspended (floating) inside the large sphere. This will happen because the repulsion from similar poles.
2 – We start with a flat magnet that has the poles like this:
What would happen if we fold this flat magnet into a sphere? There are some people that say that the magnetism will be cancelled out once the ends of the flat magnet meet. But I believe that the magnetism will be contained within its walls. If we drill a hole into that sphere and place a steel nail in the hole, I believe there will be a magnetic force there.
Now let's consider another option of making a hollow sphere magnet. Manmade magnets are created by shaping the material (ceramic, neodymium mix, strontium, etc.) and then applying a strong current to the material for a short time. Once the current is removed, the material becomes magnetized and we have a permanent magnet.
Here we have a hollow sphere of magnetizable material and we apply a strong current like this:
Can someone tell me where the poles would be? And why?
Ed
