Okay...
somehow you can't see something that I can see, or I haven't explained it well enough, or something else is getting in the way; I don't know.
Here are the pictures copied from my website:
http://www.sparweb.ca/3_Gen_MoCo/Baldy.html
PERFORMANCE TESTING OF THE GENERATOR (June 2010)
Using the lathe is very convenient for me. It's a 5HP power source that can drive my generator at any speed I care to use.
I hauled a whole bunch of batteries with me, and I wired up that board in advance so I wouldn't piss around while at work. The planning paid off because I got in, did all the tests, and packed out in 5 hours. I brought my old Wattmeter with me, and it was indispensable. It's much simpler just reading off that steady needle than trying to decide which of the 3 decimal places to keep on a DMM. Speaking of DMM's, they actually agreed with each other most of the time, a nice surprise. Just to illustrate and have fun, I ran the current (about 40 amps) through a thin piece of wire (last picture) and made it glow nicely!
The reason for all this stuff is so that I can measure both the input torque and RPM. With those figures I have the input power. With the wattmeter on the output side, the analysis gets pretty simple: efficiency is power_out divided by power_in.
All of the tests used 24V batteries. Maybe I could have tried 48V but I can't contemplate a 48V system at home right now, so it would be totally academic. The goal of the tests was to size up the prop, and identify the preferred connection scheme for the generator. I don't know if everyone would agree, but I'm leaning toward Jerry (individually rectifying the phases).
The lathe drives the shaft of the generator. There is a tachometer on the lathe to give independent confirmation of the speed.
The body of the generator is free to rotate except for the wooden board. While the generator is forced to turn, the end of the bar rests on a scale which stops the body from turning. The force at the end of the bar gives the torque.
This is explained in a Youtube video:
http://www.youtube.com/watch?v=604dgSMzvu8Electricity generated by the generator is rectified.
Electrical load is battery charging.
There are some other components but they aren't part of the data collection tests.
A shunt was used for current measurement. A true-RMS meter measured voltage, and independent of those is an analog wattmeter.
Verbal explanation in a Youtube video
http://www.youtube.com/watch?v=baOZut11B2ESo I hope this clarifies.
Here again are the data that was collected from these tests:
What this means is that the data that creates the input power graph is composed of only 3 measurements, taken directly:
RPM (measured by tachometer)
Force (on scale by arm)
Distance (of reaction arm)
Note that none of these measurements are dependent on any electrical operation at the other end. They are physical measurements taken using the prony brake illustrated earlier. The tools used for each measurement were tested for accuracy, and in the case of the scale, it was even calibrated.
Further, the data that created the output power graph is composed (again) of direct measurements:
DC voltage
DC current (true RMS)
I admit that the DMM measuring voltage is not calibrated, but at times I swapped them and got the same results on each meter. And the wattmeter provided confirmation in all cases.
