Wouldn't TSR of 10 be better for higher efficiency ?
(Attachment Link)
The optimum tip speed ratio of a HAWT can be chosen in between about 1 and 10. There is an aerodynamic theory (see report KD 35) which gives the chord and the blade angle as a function of the rotor diameter, the radius, the number of blades and the chosen lift coefficient. The higher the tip speed ratio, the smaller the chord and the blade angle and the lower the Cd/Cl ratio must be to get an acceptable Cp. A very high tip speed ratio like 10, requires a very low Cd/Cl ratio of about 0.02 for a 3-bladed rotor to get a theoretical maximum Cp of 0.45 (see KD 35 figure 4.7).
For a normal H-Darrieus rotor, the blade angle is fixed at 0° and you have to use a symmetrical airfoil because the angle of attack varies in between a large positive angle if the blade is just at the front side and a large negative angle if the blade is just at the back side. The fact that the blade angle is fixed at 0°, results in only one optimum tip speed ratio. In my public report KD 601, I have calculated that this optimum tip speed ratio is about 4.2. If the tip speed ratio is smaller, the airfoil will stall, especially at low Reynolds numbers. If the tip speed ratio is bigger, the angles of attack will become too small to generate sufficient lift. The variation of the angle of attack is given in figure 2 of KD 601 for twelve positions of the blade if the tip speed ratio is 4.2. So it isn't true that you can chose the optimum tip speed ratio for a H-Darrieus rotor and certainly you can't chose for a very high optimum tip speed ratio of 10.
The fact that the angle of attack varies in between a large positive value and a large negative value, means that only for a small part of a revolution, the airfoil is working for the angle of attack for which the Cd/Cl ratio is minimal. The average Cd/Cl ratio will therefore be higher than for a HAWT which can be designed such that the Cd/Cl ratio is minimal for every part of the blade. The maximum Cp must therefore be lower than for a well designed HAWT.
So I don't believe that your presented Cp-lambda curves are correct. If these curves are the result of measurements, the wind speed must have been measured incorrectly. The Cp is defined with respect to the undisturbed wind speed V and for that wind speed you must measure at least three rotor diameters in front of the rotor. If you measure in the field close to the rotor plane or in a closed wind tunnel, the Cp will be much too high.
