After building my (one and only) axial alternator I tried this test:
The alternator magnet disks were spun on the lathe at various speeds, with no stator in the way.
Within the gap, I inserted different bars of aluminum. I inserted the bar as far as I needed to get the full effect, basically deep enough that the field from magnet to magnet was passing through the whole bar.
Test 1:
Solid bar, 3/4" square. This had the strongest effect. It was difficult to hold the bar straight and not scrape the sides when spinning at 700 RPM.
The difficulty was not due to attraction, just effort to keep the bar steady with such a strong force pushing against it. The bar was being pulled with the rotation of the magnet disks.
The bar also started to get hot in my hands.
Test 2:
Bar made of 3 laminations of 1/4" thick pieces, together making a 3/4" square bar. This I also pushed into the gap of the mag rotors up to 700 RPM.
When the laminations were oriented face-to-face with the magnet faces, the force was almost as strong as when the solid bar was in the alternator.
It also started to heat up.
Test 3:
The same bar, but turned 90 degrees. The 1/4" pieces were edge-on to the faces of the magnets. When that was passed between the magnet rotors, the resistance was DRAMATICALLY reduced.
I was able to run the lathe much faster (1000 RPM) and still held it easily. The resistance wasn't zero, but still easy to hold, with no sign of heating.
Note that I was measuring the RPM of the lathe, not just going by the rated gear ratio, so during the solid bar test the resistance held nominal 770 RPM the speed down to 730, while the edge-on lams it ran at 760 RPM. The same happened at lower speeds, but the handling forces and slowing effect all grew stronger at higher speeds - more than just in proportion to the speed.
