Author Topic: Why is this fuse blowing?  (Read 673 times)
adobejoe
« on: April 01, 2020, 10:01:48 PM »
I have a bergey 10 KW unit here in Wyoming. I generate about 8,000 kWh per year and it has operated over 15 yrs with little maintenance.  There is a 35 amp fuse at disconnect at base of tower then about 600 ft buried run and a 50 amp fuse on same conductor at entry to inverter. I just blew the 50 amp fuse which is the second time in two years. I guess my question is why the 35 amp fuse is not blowing first. The 35 amp fuse has never blown.
Going to get a backup fuse (busman Fwh-50) butt maybe I should get a 60 amp....?
Andy
XeonPony
  • Sanity is over rated!
Re: Why is this fuse blowing?
« Reply #1 on: April 01, 2020, 10:48:15 PM »
No if it is blowing there is a reason for it. So some reason over 50 amps are getting pushed through that fuse to some where.
Do you have a camp on amp meter ?
Start tracing current flows. See if there was a defective batch of fuses, ambient temps, and such.
« Reply #2 on: April 02, 2020, 01:06:13 AM »
Wild a** guess #1:
Different fuses blow at different speeds.
I can't really explain all the details but it is possible that a 50Amp fuse is so much faster than a different type of slow 35A fuse.
Wild a** guess #2:
There is enough capacitance in the buried 600ft run that when the inverter flips On, it accepts a momentary surge as the capacitor is discharged.
adobejoe
« Reply #3 on: April 02, 2020, 09:37:29 AM »
Spar. I like your answer...capacitance in wire. The 35 amp is closer to the turbine so you would think that would go first.  I will keep a 60 amp spare. Thanks!,
« Reply #4 on: April 02, 2020, 10:30:19 AM »
I find it difficult to believe that the energy stored in wire capacitance could even tickle a substantial physical fuse wire never mind get it hot enough to melt.
I'd be more inclined to believe a fast-blow vs slow-blow thing.
Or maybe there is some other curious intermittent wiring fault.
« Last Edit: April 03, 2020, 03:21:47 AM by DamonHD »
« Reply #5 on: April 02, 2020, 10:32:13 PM »
Try 0.3 uF per kilometer for dry wire.  The run is 600 feet so we have 2 conductors * (600*0.3048/1000*0.3) = 0.055 uF
That will store a micro Coulomb of charge.  It will discharge about 10 microAmps at 60 Hz.
After a day to think about it, that's not it at all.
Can your wires handle the 60 Amps?
