Author Topic: An Proto-Teach Éireannach  (Read 52192 times)
Scruff
  • Country: ie
Re: An Proto-Teach Éireannach
« Reply #165 on: November 19, 2020, 04:48:13 PM »
Uh oh! They're on to me!!
 :-X
There's ~€175 worth of temperature sensors in this picture. Ingredients for another €210 outtov shot.
I decided not to copy Studer with their wall mount RJ12 boxes.
I like to heatsink my temperature sensors...I'm a bit odd like that.
That reduced my build component cost to about €3.50 per (10x cheaper than OE)
I put the lead ones in cable lugs for connecting to battery terminals.
The Li-ion cables might get hot so I went with the T092 chip, kapton & aluminium tape to the side of a cell.
Not a bad match.
WuPoG now has (tier 2) Low-Temperature Charger Foldback.
Scruff
  • Country: ie
« Reply #166 on: November 19, 2020, 07:42:09 PM »
I realised I was in danger of almost finishing three projects!  :o
So I started another just to be safe.
Don't be fooled by the label (not changing it).
Shore = Utility (Grid), Ship = Powerplant (Back Up).
$7 63A K&N ChangeOver Switch, no point in getting fussy about labels!
Scruff
  • Country: ie
« Reply #167 on: November 20, 2020, 05:05:06 PM »
Don't be sad when your inverter can't cut it anymore.
It's probably the power lekytronics gods saying " You can do better!"
When it takes you 3 hours to close the lid it's time to stop adding kVAs.  :D
...I didn't say to a battery!  ;D
« Reply #168 on: November 21, 2020, 07:14:45 PM »
Scruff,
Have you heard this song enough in your lifetime?   https://www.youtube.com/watch?v=r5tk8c_hOZc
Scruff
  • Country: ie
« Reply #169 on: November 21, 2020, 09:19:44 PM »
Kindov appropriate SparWeb,
It amuses me when people are trying to green it up by going off-grid.
The greenest method is to stay on-grid and make the grid green.
Green being and green doing can be quite ironic sometimes.
Here's another good one for ya.
It's about my affair with MasterVolt;
(I've thought about posting it several times)
Scruff
  • Country: ie
« Reply #170 on: November 22, 2020, 11:44:26 AM »
House's are too easy!
Scruff
  • Country: ie
« Reply #171 on: November 24, 2020, 03:31:24 PM »
I'm testing and finessing as a background task lately. At the moment I'm synchronising 2.6kVA to 3.5kVA with a synchronised 1.8kW GTI synchronising to 4kVA. So far it's all working pretty well. With um....7.5kW of charging capability + a GTI on the sidelines.
Leadite is running charger burn test currently. 55A @ 24V, 40°C holding.
The Ship to Shore ChangeOver is tripping WuPoG's RCBO when she's synchronised but not when she's soloing. hrmmm...
I got this far with the powerplant's battery discharge test.
The DC meter is not registering Lead-Fi's battery contribution.
The AC meter is.
This was a sensible place to stop the test and let the battery rest for balance checking.
Next day I had a look.
Ever heard of the expression herding cats? ±200mV across pairings with some sub-battery sets.
This is an undesirable issue. It called for another of my bespoke high fidelity, ruggedised solid-state, passive balancer inventions.
I added centre-tapped interconnectors. Cable gauge was carefully selected in accordance with what I had lying on the floor nearby that I wouldn't have to fuse. (35mm²)
Sold.
« Last Edit: November 24, 2020, 04:00:00 PM by Scruff »
Scruff
  • Country: ie
« Reply #172 on: November 27, 2020, 05:20:26 PM »
Well the passive balancing isn't perfect. I've some jiggery-pokery to do with the pairings. I used a limited feedback loop to manually active balance.
Looks like I've 20kWh to play with
Now about this 50% rule of thumb.
I recall looking at a graph and ascertaining that this was a sliding scale of cost effective energy extraction.
It's been brought to my attention that I'm either mistaken, out-dated or the current data is not the same.
Same amount of lifetime extracted energy everywhere on the curve.
I'm not afraid of sulphation because I have real proper chargers. It may be a factor for everyone else who doesn't base charger selection around specific gravity performance...I know right, who'd build or recommend a charger they haven't proved can charge a battery first right?..
Scruff
  • Country: ie
« Reply #173 on: November 27, 2020, 05:28:59 PM »
I thought I'd take a moment to witter on about ApprenticeVolt's ineptitude and inflated ego.
This €300 meter here. I adjusted the assumed capacity to the apparent capacity by +30Ah. It reset itself to 100% charged the moment I did.
Why does this have one adjustment direction and two buttons?
..so tedious...
Every battery name in this is a "bank" that's just pretentious to me. A cell bolted to a cell is a battery. A battery bolted to a battery is a battery.
A bank is a what? Place where I get more energy the longer I leave it in there? A way to sound important?
Engine bank, house bank, bow thruster bank, service bank...spare me.. ::)
Scruff
  • Country: ie
« Reply #174 on: November 27, 2020, 05:38:51 PM »
Leadite has graduated bench test to the field! Whoop!
The last thing I had to check was my genset triggering.
I built a circuit that on SOC threshold either turns off the inverter output or if you press the secret hidden switch maintains the inverter output and sends 12v sig to the genset (Bruno probably).
Here's a genset I built earlier!
It VorkS!!
You know what that means?
I'll be starting that truck anyday now! Whoop!
I had a look at WuPoGs RCBO anomaly. I think it's the breaker sensitivity...I know right..electrician blames the circuit breaker...red flag...we'll see, we'll see... There was no issue until I changed to the one she's currently sporting, no load fault found and it is extrememly fast reacting...
Scruff
  • Country: ie
« Reply #175 on: December 05, 2020, 04:07:39 PM »
Phew...3 days sorting 1000s of tiny things and tens of big ones. I've tidied the workshop. I've been using the I don't want to raise conductive dust excuse with all these open leckytronic boxes around for months.
I do an awful lottov angle grinding all the same..don't ask me how I get away with it.
I've noticed that the XTM temp. sensing is conservative too. I set it to 30mV per degree and it reacts as 20mV per degree....I think I'll investigate this more closely later.
Pilot error.
Confusing 3mV per cell and 30mV per (12volt) battery
Has anyone else noticed what a marvellous tapestry of meter shots this thread has become?  :-[
I've been putting WuPoG through her paces...cwaor she's Sh1t Hot if I do say so myself! Dumping ApprenticeVolt was the best thing I could've done.
C1
One of the many things I like about Studer so much is they do their continuous rating continuously!
High cost of science!
I isolated every battery in the powerplant. Charged them one at a time on the same 12v charger.
Left them sit for 2 days.
Rearranged them according to matching holding voltage series sets the ones that were close enough went in parallel.
The GelAgm + AgmAgm is still not perfect. But altogether it seems to be working now ±25mV with centre tapped cross-linking. If it starts drifting again I'll go active balancing.
Souper Charger Mk-II graduated.
Scruff
  • Country: ie
« Reply #176 on: December 15, 2020, 04:44:00 PM »
I took a trip to Froya onna ~+50% operational load efficiency hike mission.
I realised I hadn't uploaded the solar array since we prettied it up.
1220Wp 40Voc (4 parallel to minimise charge controller singing)
Clients are running 2 different generations of macinposhes.
Google Home (voice-activated music and oddity dufer)
An internet transciever booster.
And a sterling lump quiescent to power them.
Tinternet transceiver is a native 12VDC
I hardwired that Meanwell DC-DC reg to a 3-way socket with 3 x 12Vdc outs (cig lighter socket) a USB QC3 and 3 x USB 2.0s
The hub can be used for tvs, external hard disks and anything else 12v flavoured, untroubled by charging voltage.
GoOgle home is 17V
I used a multi-voltage reg for this.
One macinposh is MagSafe 2
£55 for your pleasure... ::)
Thuther macinposh is USB QC 3
£5..non-proprietary..see how that works?
I took some energy meterings on the way out.
The alternator trinity is unmetered.
I usually calculate it roughly by seeing how much more the solar does in the Summer.
Scruff
  • Country: ie
« Reply #177 on: December 15, 2020, 04:52:47 PM »
WuPoG got a new RCBO. Now she synchronises seamlessly.
A trade sparky tipped me off he found Schneider to be more wholesome than Hager.
The new RCBO is earth referenced by it's own PE lead.
I'm not sure if that makes a difference. The original 2U Hager that worked as well wasn't.
I believe I have gotten to the bottom of where my charger (smart-boost complaint) kept effing off to.
After another factory reset and systematic entry of every changed parameter followed by reenacting load profile parameter behaviour observation feedback x2.
It seems it was tripping overvoltage for some reason when in certain load conditions when loads were added. The reset threshold was set to low (being li-ion and not renowned for as significant voltage sag). It was locking out the charger as a result. Seems to be working fine now after I set the thresholds outtov range. I can tier one with the MS relay driver and let the XTM run critical threshold.
... ;D er yes all the safety disconnects are at least 2 tier cascading some are 3 tier.
Eg.
LVD 1: Turn off inverter output
LVD 2: Turn off inverter by soft switch.
LVD 3: Disconnect battery (forcing the user to phone me and tell me how they managed to do that so that I tell them where I've hidden the ignition key)
I maintain as ever that if we invested as much in protecting our lead as we do our lithium it would perform as well for as long except for much less cost (half price to one sixth depending on scale) and double weight per usuable kWh.
« Last Edit: December 15, 2020, 05:17:03 PM by Scruff »
Scruff
  • Country: ie
« Reply #178 on: December 17, 2020, 04:23:22 PM »
I forgot to mention we tracked down Froya's engine battery parasitic. It's the Chinometer....25mA  ::)
Much like the ABS fault in a car being the ABS sensor and not the braking system...we disconnected the art and I said I'd put a switch on it later. Engine battery parasitic is now 5mA.
Alternator regulator is fine but I'm still receptive to ideas on how to resurrect the battery light without affecting the regulation.
In keeping with the theme of increasing battery efficiency with Meanwells. I deleted my home energy meter battery.
Dry cell batteries...most expensive power on earth!
Inside the Ship to Shore ChangeOver enclosure.
Those doughnut devices are not accurate by the way..±200W
...and it reads backfeed as consumption which has propagated a barney on one occasion.
It was free.99 though!  ;D
Scruff
  • Country: ie
« Reply #179 on: December 17, 2020, 05:08:49 PM »
I nearly have WuPoG dialled in. LVDs, HVDs, effective capacity, thermal management, discharge/charge aperture, low temp foldback, critical disconnects, meter calibration etc. etc...
I may have mentioned how clever the Swiss are. It's next level, nobody can touch them, this is one of the few products I can't find fault with (Jury's out on the charge algorithm...I'll follow that up some time, for the moment I'm still seeing MS do better)
This:
Actually works.  :o
It's impressive.
I'm a little underwhelmed with Li-ion. It's a lighter alternative the rest is marketing.
Soo finicky and complicated and this BMS lark and not integrative with conventional hardware.
Eg Li-Fi versus Lead-Fi Application Notes.
Anyways I can charge extra because it's fashionable  ;D
And she's already about 120kg...sooo yeah, there's that.
She's been derated.
Perhaps it's more accurate to say she was over-rated.
She's 18S 72A CALB LiFePO4 bricks.
This amuses me because the market says "48volt" compatibility is 16S, there's an example of not thinking (maybe). 12v is 4.5S making 24v 9S I am guessing they say 4S for convenience and then times 4 etc.
Another thing people say is you can use 100% of the battery...you can't but the bit you can't use is hidden by the BMS. Some are designing to 90% (short cycle life) whereas the more prudent are operating to 70% (longer cycle life).
From what I've seen the extra 20% can >quadruple the extracted energy 100% depletion = 600 cycles, 70% depletion = 3000 cycles.
What pi$$es me off is when they say it's good for 3k cycles and then BMS it to 1k cycles for outtov the box performance...a rather all too common practice. Is it lying, is it marketing? You decide.
I'm working to 60% depletion because I know people and the first thing anyone does with a show battery is plug it in all day until they need it. I've limited the Absorption to prevent heat-induced plate deterioration and placed a dump excess to grid low float reduced SOC for on charge storage. This battery storing at 50% is not as good as lead's 100% for a lottov applications outside of underspec-ed input systems.
I have to leave overhead on the bottom end too because those same people are unlikely to charge it after they are done, they'll just stick it on a truck and ship it back to me after storing it in their warehouse over the weekend.
WuPoG is now 2.5kWh
With an impressive 80% empirical NOC round trip efficiency.
So how on earth is a >4kWh battery producing so little.
Here's my operational envelope
Graph taken from here. That author has inspired me to believe he's smarter than your average bear and the info therein is unbiased.
I've 18 x 3.25V cells x 72Ah = 4.2kWh + 10% because they are genuine CALB = 4.6kWh
I'm using 60% (not a far cry for 50% lead acid is it?...but arguably I can use 70% lead because I can overcharge and offset reduced cycles against linear cost per kWh)
60% of 4.6kWh = 2.8kWh
@ 90% inverter efficiency = 2.5kWh
Truth hurts. I think that's a ~€2k battery (before the BMS). I can pull 4kWh from a 24v flooded golf cart battery no BMS because the expense and volatility of the battery doesn't warrant one beyond the inverter protections for about a quarter that cost...
I think I'll start pushing Oasis Firefly AGM, people don't like flooded. I'm not convinced Li-ion brings much to the party in a static application.
« Last Edit: December 17, 2020, 06:32:20 PM by Scruff »
Scruff
  • Country: ie
« Reply #180 on: December 18, 2020, 09:51:04 AM »
I was doing some reading on the advanced properties of LiFePO4 last night.
So I'm supposed to store a battery empty? Not useful!
It has a memory effect?!
And to compound the memory effect I'm not supposed to fully cycle it to avoid lithium plating if I want it to last and the capacity to not deteriorate...but if I don't fully charge then I lose capacity due to the memory effect.
ffs!  ::)
« Reply #181 on: December 18, 2020, 01:09:14 PM »
I basically parallelled my LA and LFP packs on the grounds that the LFP would prefer to spend time empty while the LA would prefer to spend time full.  It seemed to work:
http://www.earth.org.uk/LiFePO4-battery-testing-with-solar-PV-off-grid-system.html
Scruff
  • Country: ie
« Reply #182 on: December 18, 2020, 02:39:37 PM »
Hrmmm, yes Damon, it does work to an extent. It'll help with voltage stabilisation and reduced peukert but it's hardly ideal. Better for the lead than the LFP.
This memory effect thing seems to be LFP's dirty little secret. It pretty much undermines a lottov purported benefits.
It's actually pretty well documented almost a decade. And yet battery university (not that reliable a source in my experience) and most proponents are adamant it's not a factor. It's a highly inconvenient phenomenon.
As regards mixing LFP and FLA for static traction. I wouldn't I can get 30kWh of OPzS delivered to my door from Poland complete with an automatic watering kit, hydrocaps and a stir kit for what I got 4kWh of LFP for. My applications suit a battery that can be stored at 100% SOC and micro-cycled.
As with most things you never know until you know. WuPoG has been running the same memory write daily for a week now so I can measure this.
I've dialled the charger up to 3.5v p/c with a tail current of 1A and a dump excess to grid float voltage same as yesterday. I'll run a discharge test tomorrow and if I get more than 2.5kWh I may decide to put a bee in my bonnet or grow a camel hump or something...find a rafter to cry from...hohoho..
Anyways lets have some Christmas Polytunnel eye candy (the real-life one is ever so tastefully palette cycling) to take our minds off it for now. I'll stichk another hot whiskey on..
Seems every time I look at battery performance per € spent where the system has a fit for purpose BMS, lead is unrivalled.
« Last Edit: December 18, 2020, 02:57:40 PM by Scruff »
« Reply #183 on: December 18, 2020, 03:51:20 PM »
Yeah lead still wins, as long as you don't need the battery to travel around.
That tent looks awesome in those lights!
Scruff
  • Country: ie
« Reply #184 on: December 18, 2020, 04:48:28 PM »
LFP is only half the weight. In terms of mobile applications that don't fit in your pocket (not electric drive for obvious reasons) it's not even that significant; the most anyone'll be lifting/hauling around is <3kWh.
So effectively <35kg or ~12kg per kWh.
Comparing FLA Trojan T105 to CALB CA100.
before I weigh the BMS and the BMS mounting hardware.
High C-rates with low energy volume are useful but niche.
WuPoG is a torque filling unit. The marathon runner is coming soon.  ;)
If you want most of the benefits of li-ion without the pain in the hoop ones and all the benefits of lead for half the LFP price from all reports I've seen Oasis Firefly AGM are the ticket.
The polytunnel's fun alright, the condensation on the skin gives the source a good impact.
The neighbour's like it.
I laugh to myself about turning swords into ploughshares regarding covid & the events industry. I haven't made a giant snowflake light bounce around a hotel conference centre ballroom Christmas do at all this season and I can't say I miss it.
It's ~10m of RGB LEDs and some scrap Chinese controllers. I'll get a pic of the driver in the daylight.
I had a drawing all about the Pb vs Li-ion application guidelines....rummage..
..Ah ha!
« Last Edit: December 18, 2020, 04:59:57 PM by Scruff »
Scruff
  • Country: ie
« Reply #185 on: December 19, 2020, 03:55:43 PM »
Hohoho!
Here's the Discó nA mBó LED Driver Unit
Order of magnitude overspec-ed PSU but that's what I had to hand.
Complete with a Professional Control Interface, I have boxes of these and the drivers as job leftovers from theatrical set installations what got thrown out as parts we don't need for later salvage.
I did the stove hearth too.
That might become a permanent feature except with trunking a photocell and LEDs that aren't hacked together from scraps.
Scruff
  • Country: ie
« Reply #186 on: December 19, 2020, 04:27:06 PM »
Onto more concerning matters, hard to find bees this weather. The hump is inbound and I've a rafter ladder at the ready...
I ran a memory releasing cycle last night on WuPoG. Truth be told first ever. I wasn't too bothered firing up the balancers because that'd mean I'd haveta take her outtov the case and they sing an audible rendition of Chinese water torture (HF ~13khz..hey hardware engineers stop using carrier frequencies in the audible spectrum willyas?! It's lazy and highly nauseating)
I dialled the charger up to 2.53V p/c and ended the charge with a tail current of 50mA.
For the record LVD is dialled in very tight. It'll trigger at the same setpoint with varying load conditions thanks to the Swiss being the smartest most diligent effers I've seen.
The test load is my house so the load conditions are NOC.
I decided the first cycle after a memory releasing cycle means nothing because the dump to grid wasn't metered and I just did a 100% SOC cycle not my standard 80%
I let her bounce off the LVD threshold. Restored her to the former absorption setpoint, cycled her again...low and be-effin'-hold it's a thing!
10%  >:(
I think that's significant.
LiFePO4 requires EQ cycling!?
Does this mean reduced SOC depletion does not increase longevity?
Does this mean an awful lottov proponents are talking through their hats, and believe everything they read than supports their point of view without any data to back it up?
Does this mean a lottov sellers aren't giving us all the facts? Or telling people the opposite of the truth...what's the word for that...? It'll come to me...
Does this mean the professed benefit of using them instead of lead because you don't have to periodically fully charge them is in fact horse manure?
Does this mean drop-in replacements are intrinsically flawed by the interests of the BMS writer?
Does this mean short/micro-cyling them like for off-grid & liveaboards could be problematic?
All well and good saying oh just EQ them so...ha...I've love a lesson in how to do that from Joe Average Bloke.
I haven't noticed much in the way of significant efficiency improvement over well-maintained lead either, for those not following so closely.
But it gets better they don't like high SOCs so after you charge them you have to dump 15>50% if you want them to last.
Meaning they can't be left in a useful float charge or held high to trigger diversion control or stored for backup.  ::)
If you charge them, then attempt a low float without a load or a means to backfeed then deterioration because no load = held high.
And they set fire if you charge them below freezing...ok we all know that but I thought worth mentioning.
Excuse me, while I go haul me ladder over to the fanboy club and I'm taking a trip to the more money than sense house after..
« Last Edit: December 19, 2020, 06:33:26 PM by Scruff »
Scruff
  • Country: ie
« Reply #187 on: December 19, 2020, 04:50:19 PM »
Having said all that, I'll rerun the test later to verify the thing is a thing and not an anomaly.
After all, it's not scientific if it's not repeatable.
I'm not shy about eating my words so I will post any further data I gather.
MPPT being so much better than PWM really surprised me. I think the results will vary a lot closer the equator though. Apparently, Greece is far enough south.
Lost another meter on WuPoGs Output last night. Second one...hrmm...
This is why when I buy cheap yolks from China I buy lots.
I opened it to see if it was obvious.
Nope.
Also €15 so fell into the not worth fixing salvage bucket. Spare fitted.
I wonder if it's WuPoG or the meters. These aren't very reliable but they are incredibly accurate and cheap.
Scruff
  • Country: ie
« Reply #188 on: December 20, 2020, 07:04:07 PM »
Hey ApprenticeVolt! Pop Quiz! What's 280Ah divided by 0.6Ah
10days 6 hours and 15mins you say?
Nope!
Bank my bottom!
Scruff
  • Country: ie
« Reply #189 on: December 20, 2020, 07:11:06 PM »
Spare WuPoG Output meter is down... :-\
Time to stop sending miners to investigate the gas leak I think.
The "seamless" transition from thoughput to Inverter is a mite concerning twould seem.
What do you folks reckon?
I'm gonna ask Studer to see how they run.
Here's a few captures, on-load / off-load doesn't make a difference.
Gnarly huh!? Don't blame the meters...
Scruff
  • Country: ie
« Reply #190 on: December 20, 2020, 07:18:52 PM »
The transfer from inverter to through is much better
You can observe a slight amplitude increase as the Xtender synchronises and a reduction when it transfers.
The highlighted portion is about 6 seconds, factory default transfer time
Here's a close up of the step from dual synchronising to throughput
Scruff
  • Country: ie
« Reply #191 on: December 20, 2020, 07:29:33 PM »
I'm cycling Li-Fi to validate LFP memory effect symptoms.  :(
I basically charge one inverter gen from another so I'm not wasting loadsa energy. Just losing system inefficiencies.
The house energy meter is reporting high because it first accumulated the kWhs into the batteries as a house load then what I "dump" into the house after is a double register of that same power.
The reason I get away with my antics is I'm filtering my gen under test through the powerplant battery & 24v 3.5kVA XTM and boosting it where necessary.
The test gen. can hit LVD shutdown and I might not attend to it for any amount of time. Once it does the powerplant XTM takes up the load giving me 10kWh of runway and no unscheduled blackouts.
I have tripped overload on the solo 3.5kVA a coupla times but I usually see that coming. You generally want 6kVA for a house.
Scruff
  • Country: ie
« Reply #192 on: December 20, 2020, 08:11:52 PM »
Switch Bounce!
Try unplugging it instead!
Faster
Faster
...hrmmm... dunno..
Scruff
  • Country: ie
« Reply #193 on: December 21, 2020, 06:05:18 PM »
It's not switch bounce.
Here's the switch operation.
It's not unique to WuPoG
Here's the 24v Xtender
It's not the Zero Crossing 45A SSRs
With (thru):
Without (bypassed):
« Last Edit: December 21, 2020, 08:18:30 PM by Scruff »
Scruff
  • Country: ie
« Reply #194 on: December 21, 2020, 06:32:54 PM »
Hrmmm...
Autopsy reports the meters are blowing regulation zeners, and probably everything downstream after, I stopped investigating after seeing that.
Kindov middle of the road, least you could do, you get what you pay for mains filter, I'm not seeing a choke for one..
Up to this point I've been using this as a O-scope filter.
I callit The Sine Whisperer.
I've hacked it to have a panel mount BNC output of the 24v transformer secondary because:
The transformer could be contaminating the data so I made another scope lead...er...I "advise" you don't do this at home...it's potentially another widow-maker.
She's sporting a 12MΩ resistor soldered across the fuse holder. er...yeah...callit 10X probe will we?
And of course I need a mains "isolation transformer" or battery powered scope too...sher have both they're on sale!
Scruff
  • Country: ie
« Reply #195 on: December 21, 2020, 06:45:05 PM »
Other than weaponising the test apparatus it didn't improve much.
Every time I doubt the Swiss...I realise....don't..
Change tolerant to fast.
Zing!
Sold!
Miners! Yer going back in! I need 4 more cheap as chips DIN meters stat!
Scruff
  • Country: ie
« Reply #196 on: December 21, 2020, 06:50:30 PM »
I ran a Li-Fi apparent capacity check (with Irish LVD, not Swiss)
Followed by a memory release cycle 2.53V p/c with balancers to 150mA tail current. (takes all bleedin' day)
Dumped that into the powerplant.
Reloading her now from the powerplant on the same setting as the apparent capacity check.
I updated some firmware while I was in there and think I found a way to reduce the charge time by 1 hour.
Pending results she may require a rework with a maintenance cycle/more cowbell secret button.
« Reply #197 on: December 21, 2020, 07:37:42 PM »
Hi SCR- uff
What I was thinking is that you need the option of being able to post more than 7 images per topic/lead ...
You can get into contact with TechAdmin and work with him directly. Its just the way it is with these phorum capabilities.
Best
Jeremy
