lessons learned in gennie building....
( grab popcorn )
i first started out with a clear direction of building a micro wind turbine to run a smart phone.....and i thought i could do it by harvesting magnets from diacared smart phones. Than i learned about N-S confighration. I even kept my little stash of magnets for historical purposes. Thats them! Cant see them ? They are dead center in the middle of the ginormous stator.
Ever try to find the polarity of a magnet that small? i tried ......anyhoo....moved on. My very first real stator was actually quite a feat of engineering , considering all my knowledge came from about ten mins of youtube. Than i learned after the fact that you cannot solder anything to bolts with out a welder....And my mold should have been lined with parchment paper. Oh i also figured out that you cant tell how much resin is poured by looking. Its clear. So some coils came partially bare, the mold was not well planned.
Result: 3-5 days of gently removing paper from resin pour. ( resin eats through foam board. i decided to use foam board due to it being cheap and easy to manipulate. Also, it greatly pays to line your mold with parchment paper and packing tape. Dye the resin also greatly helps to judge whether the coils are flooded also. Power connection? i learned that i can acquire really awesome male / female connectors for the line outs. I wont even show my second stator. its le miserable!.
Actually, look above. Thats number two. This is number trois.
Wire management. My next stator REQUIRES a major rethink so i avoid having wires sticking out the surface....So i am taking proactive measurements and training my coil legs before they get joined.
I feel that i am going to make massive headway soon. My goals is to attain this level of craftsmanship soon.
And i found the bearings , the axle, the connectors , metal plates for rotors and 3d print the end plate. This has been the most satisfying hobby of my life to date. And , i found out that you can shrink them down and sell it as a drone motor or rc plane motor! . So i set out to build a little hand held wind turbine to power up a phone ( 5v 5w ) and got totally lost....
