Okay, so I think I grasped that.....
SO, lets go with Alternator Example A:
Designed to have an output of say 55 Volts to charge a 48 Volt Battery Bamk.
And, with nothing on the alternator it produces 55 volts
With out a load, if Alternator Example A is setup, and all the sudden the wind doubles or tripples the alternator can possibly
spin itself to death via producing to much Voltage and Amperage?
Than wouldnt Alternator Example A requirements be the 48V battery bank, Voltage Drop from the wind turbine to rectifier and batteries + load? ( what ever V+A this is )
And, if I have this correct, than really, I would need to produce an Alternator that is capable of ALOT more than 48V yes?
Why couldnt I just design for 48V and somehow do an electric or mechanical break so that I can forgo the math for figuring out the load?
