Using ferrous magnets stacked didn't seem to amplify the magnet field strength. It barely got stronger with each successive magnet in a stack. So I decided to play with steel bars to try different ways to connect them. When all six were stacked on the same side with polarities all in the same direction it was surprisingly ineffective. The bar itself did not act magnetic at all. One way using the bar, however, had an interesting ability to increase the strength. I used two stacks of 3 ferrous magnets on a 5"x3/4" 16ga bar. But when I moved one stack of 3 magnets on the opposite side and at opposite end, where the polarities were also mirrored, North touching one side of bar and South on the other, they suddenly got substantially stronger. Not only that, but the steel bar is suddenly strongly magnetized. The stacks are completely touching the bars lengthways, no overlap. And there is about an 1-1/2" gap between the two stacks, where neither stack covers. If I widen or shrink that gap between then they don't combine field strengths as well. With a gap at 1-1/2", there is a significant combining effect of the magnetic field.
Does anyone know why the magnets suddenly strengthen along the gap in the bar - and under each stack - far more than all six magnets in a single stack? And why is it when that gap is only at a certain distance it works better?
