Author Topic: A new 9.6KW PV Static array.  (Read 2202 times)
clockmanFRA
  • Country: fr
    • Renewable Energy creation
« on: August 01, 2022, 11:18:10 AM »
The local government are bringing in new laws to stop the farmers from leasing their Fields for Solar PV companies.
What the local government says is that good agricultural land will be taken out of production.
As usual i am upsetting the apple cart.
We have just applied for planning permission before the new rules will take effect. As we are a small farm and registered for sheep. Although our new PV array is actually in our garden.
According to the government official the PV is only just off the ground, and the ground underneath these vast PV farms will need weed killer or graveling over etc.
So here is one of our sheep under our new PV Array, its a photo with the new project exactly blended on. As you can see i raise the array by 1.1 meters so the sheep can not get at the PV panels. And we have always made sure none of our ground becomes not usable.
clockmanFRA
  • Country: fr
Re: A new 9.6KW PV Static array.
« Reply #1 on: August 01, 2022, 11:24:26 AM »
I have being try to post a photo 1.2meg but sadly the last few days all i get is this....
An Error Has Occurred!
You already submitted this post! You might have accidentally double clicked or tried to refresh the page.
clockmanFRA
  • Country: fr
« Reply #2 on: August 01, 2022, 11:25:19 AM »
14936-0
clockmanFRA
  • Country: fr
« Reply #3 on: August 01, 2022, 11:26:34 AM »
14937-0
clockmanFRA
  • Country: fr
« Reply #4 on: August 01, 2022, 11:31:09 AM »
Just one more photo JPEG 1.6meg to post and i get this now......
This page isn't working at the momentwww.fieldlines.com can't currently handle this request.
HTTP ERROR 500
« Reply #5 on: August 01, 2022, 01:41:02 PM »
I passed 15 utility scale solar arrays on Saturday when I ran over south of Minneapolis to pick up some Heliax coaxial cable. Took one route up and a different one back to hit a pizza buffet for an early supper. These were all 2-10 acres in size... all sitting on prime farmland!
« Reply #6 on: August 02, 2022, 06:33:11 AM »
What a waste of farm land.  If they keep up this 'green' urban sprawl its really going to cut into the food production.  I don't see that as being green in the end, especially the lack of recycling potential with these panels.
« Reply #7 on: August 02, 2022, 08:50:45 AM »
ClockmanFRA;
I see the stone wall behind the panels, how's the wind load on the panels?
clockmanFRA
  • Country: fr
« Reply #8 on: August 02, 2022, 10:08:16 AM »
Hi Bruce,
Here is my tech drawing.
I have had to use thicker steel, with more support at 1.35m spacing. So a fair few more legs support than normal. I will do diagonal cross bracing to lock the structure up.
Winter winds here are from the South West and as the array is facing due south there is a slight deflection.
I will have to dig 18 holes for the legs and they will be concreted into the ground and soil covered so the grass can grow and our sheep eat the grass under the panels.
« Last Edit: August 02, 2022, 10:19:50 AM by clockmanFRA »
clockmanFRA
  • Country: fr
« Reply #9 on: August 02, 2022, 10:12:15 AM »
HTTP ERROR 500
« Reply #10 on: August 02, 2022, 03:01:04 PM »
This is the pic ClockmanFRA was trying to post
TechAdmin
  • Country: it
« Reply #11 on: August 02, 2022, 04:06:07 PM »
HTTP ERROR 500
Noted and logged in the error log, thanks for the report. I think host being annoying as usual... Please do try again, it should work now.
« Reply #12 on: August 02, 2022, 09:48:53 PM »
Quote from: clockmanFRA
There is file size limit for images. This is good for the server using SMF. Its that way for a reason. There is a limit on image size. so and so. I use a 14mb camera even then I have to resize my images.
« Reply #13 on: August 03, 2022, 12:18:03 AM »
Haaa!
If you setup a SMF forum you cant even post pictures without a mod...
This is why we have a coder you have no idea how difficult it is to setup this SMF forum. I went thru the evolutionary process years ago. There have been about 4 coders and Flavio has stuck with us which is great.
I have been working on this SMF forum for years. It wasn't easy. We are way ahead of the curve. There has been a lot of work put forward. There is just a bunch of stuff that no one knows about for our application. I have seen forums crash and burn, that's not going to happen to us. there's a lot of work going on behind the scenes that I and Flavio know about.
You cant just decide oh I'm going setup an SMF forum from scratch. Don't forget all this stuff is open source.
Flavio can actually write a mod... He is that good.
clockmanFRA
  • Country: fr
« Reply #14 on: August 03, 2022, 02:58:08 AM »
Thank you Bruce for posting for me.
Thank you 'Flavio' TechAdmin for assisting.
clockmanFRA
  • Country: fr
« Reply #15 on: August 03, 2022, 03:13:10 AM »
Thank you JW.
I allways down size my photos pics to below the 2MB max that this forum says.
In this day and age i believe that Open source forums like Fieldlines are perhaps the only true way of getting unbiased information.
I do post on other World wide forums but to date i only use 4 others as these also have good tech admin support that keep their forums going and up to speed and importantly are not over judgemental.  Retail forms IE, linked to a manufacturer or large retailer are okay but can be blindsided by monetary interest.
Well done JW, and Long live Fieldlines.
« Reply #16 on: August 03, 2022, 06:40:58 AM »
Roughly 44 feet by 12 feet in panels.  Wow, that's big.
clockmanFRA
  • Country: fr
« Reply #17 on: August 03, 2022, 09:54:52 AM »
I re-sized the below drawing below 1mb and it  has posted. I did try early at 2.1mb after Flavio said all fixed, but it would not post.
14944-0
clockmanFRA
  • Country: fr
« Reply #18 on: August 03, 2022, 10:02:37 AM »
I just  looked at my drawing and !!!! BLAST. i have drawn 10 legs and not 9.
But then designers and Architects etc are Conceptual here in France, haha!!
TechAdmin
  • Country: it
« Reply #19 on: August 06, 2022, 09:53:58 PM »
It would never post at that size, wouldn't post for admins either. It does say there's a 2mb limit :)
« Reply #20 on: August 13, 2022, 08:50:53 PM »
Your design intent is for a plurality of legs...  the details are for the engineer to work out.  That's executive thinking for you.
chapeau
clockmanFRA
  • Country: fr
« Reply #21 on: September 22, 2022, 12:11:53 PM »
« Last Edit: September 22, 2022, 11:40:04 PM by clockmanFRA »
