Hi Pedro, I have almost the same setup and issue as you, Sunsynk 8.8 with 3 x 5kWh of their batteries and an i2000 istabreeze, which I also bought hoping to run it 'through' the inverter to control charging and export etc. I toyed with connecting it directly to one of the DC MPPT strings, as Sunsynk suggest, but decided to go down the AC route, hoping to connect it to the gen input, using something like the Sun GTL inverter. However, I realised the Gen input would not work so decided to simply go ac coupled and let the turbine and controller generate power to the CU and leave the inverter to decide what to do with the excess, when some is generated. Went ahead and got the Sun device last week, but bench testing also showed the voltage seems too low to start with, so not likely to get low m/s output that I was hoping would be 300 ton400 watts to run the household background.
What solution did you come up with in the end??
Thanks,
Andy
