Author Topic: Score of a life time!  (Read 57309 times)
XeonPony
  • Sanity is over rated!
Re: Score of a life time!
« Reply #33 on: June 16, 2023, 05:44:26 PM »
XeonPony
« Reply #34 on: June 16, 2023, 10:43:28 PM »
Some pictures of the second battery in one piece and better detail.
15496-0
15497-1
15498-2
15499-3
« Reply #35 on: June 20, 2023, 04:40:54 AM »
Those are fascinating pictures XP.  Thank you!
There are a lot of spliced wires going in and out of the battery faces.  Are those your modifications or did the batteries come like that?
XeonPony
« Reply #36 on: June 20, 2023, 09:25:21 AM »
(Attachment Link)
Those are for the cell heaters, they use two 1450watt pad heaters running off the 77v dc rail (So One battery rack has 2, so a total of 6 in the assembly as a whole)
That battery is factory I have done 0 to it at this point other then recovering the cell stacks by a very low constant current charger (24v 4Amp lead acid charger)
« Reply #37 on: June 20, 2023, 09:52:56 PM »
Thanks for the confirmation.
That helps me see the picture.
Any company that makes battery stacks like these ones, with extruded-profile cases, 19-inch rack mounting, Aerospace standard power receptacles, day-glow high-voltage power cables, and military circular connectors, has really screwed the pooch when they also have wires slipping in and out of the cooling vents, crimp-spliced to heating pads.
Did somebody say "last minute change in engineering"!?
XeonPony
« Reply #38 on: June 21, 2023, 04:56:07 PM »
and uses two small course thread screws into the phenolic resin to retain the DC- cables!
Top shelf components, bottom shelf assembly in a lot of areas, the connectors are bolted! so easy to re task for your own stuff.
12v and 24v DC-DC converters too!  400 dollar contractors! good grab bag of goodies
XeonPony
« Reply #39 on: June 26, 2023, 12:10:54 AM »
https://www.ebay.ca/itm/155239081667?    < BMS I got for doing 48V
https://www.ebay.ca/itm/403912335120?    < BMS for 25V
I'd recommend getting the touch screen with it, far more useful to get stats with out needing phone
if you get the battery any ways
« Reply #40 on: June 26, 2023, 11:55:03 PM »
Well, for now I'm the high bidder.  But a lot can change in 2 weeks.
Thanks for the tips!
XeonPony
« Reply #41 on: February 18, 2024, 10:18:10 AM »
Well 1 year to date and the one battery set has done great. Traded the old lead acid bank and its accessories for the winters sheep feed, feel naked with out it, so guess time to get the last ones online and make a fire proof enclosure for them!
Still have a lot of the spare parts, if any interested! Second set was no steal like the first heavy swelling in some, so just use them till they pop and save, save, and save some more to buy some lithium iron phosphates for when they go.
15852-0
15853-1
15854-2
15855-3
As they say, can't win them all, they did recover to full rated voltage.
XeonPony
« Reply #42 on: February 18, 2024, 10:21:23 AM »
Baaaaa!
15856-0
15858-2
« Reply #43 on: February 18, 2024, 10:28:02 AM »
Looks like you are going to have a god shearing this spring!
XeonPony
« Reply #44 on: February 18, 2024, 10:32:38 AM »
It is all ways entertaining, my hands ache thinking of it.
« Reply #45 on: February 19, 2024, 01:24:27 AM »
Xeon has a little lamb, little lamb...
Adorable.
XeonPony
« Reply #46 on: February 19, 2024, 09:40:13 AM »
6 total this season, sadly the 7th required some lead supplement, but the fox will have a very healthy litter of pups so natures balance is held.
15868-0
« Last Edit: February 19, 2024, 10:21:55 AM by XeonPony »
XeonPony
« Reply #47 on: April 17, 2024, 08:07:20 AM »
Well after a years break I finally started on the second battery assembly, it is a spicy one so will need to be built into a vented fire proof box.
XeonPony
« Reply #48 on: April 17, 2024, 08:09:39 AM »
BMS is fun to watch, sort of like paint drying but yet captivating.
I use a 30v smart charger to balance the one out stack.
XeonPony
« Reply #49 on: April 17, 2024, 08:16:32 AM »
more of the last stages of balancing
Last couple days been trying to get it to 100% to set the capacity meter. Next is fabricating the main interface, will be a buss bar system designed to do 23kw cont, and 42kw surge will have 4 to 4 plugs to allow fast and easy connections of battery modules or chargers, and other sort of meters & diagnostics.
and last one is an update as to the state of the first one I got online.
« Reply #50 on: April 17, 2024, 08:44:23 AM »
Interesting how the different cells change from green to blue or red and not the same cell showing the changes.
I'm guessing this will settle down once the unit it at 100% .
Still a great score!!
XeonPony
« Reply #51 on: April 24, 2024, 02:27:52 PM »
I got it loosely tied in hoping the activity will perk it up, it is now nearly perfectly balanced. I picked up some aluminium bars to make a proper buss
Will post some bms shots once I get the tracker drive fabricated.
XeonPony
« Reply #52 on: September 25, 2024, 12:27:40 AM »
Well 1+ years on and no explosions! I got the second stack online and have a 3rd to go on yet, started to make a panel for integrating them but not too far ahead with it
