Logged in users > User Diaries
Score of a life time!
<< < (8/11) > >>
SparWeb:
Those are fascinating pictures XP.  Thank you!
There are a lot of spliced wires going in and out of the battery faces.  Are those your modifications or did the batteries come like that?
XeonPony:
--- Quote from: SparWeb on June 20, 2023, 04:40:54 AM ---Those are fascinating pictures XP.  Thank you!
(Attachment Link)
--- End quote ---
Those are for the cell heaters, they use two 1450watt pad heaters running off the 77v dc rail (So One battery rack has 2, so a total of 6 in the assembly as a whole)
That battery is factory I have done 0 to it at this point other then recovering the cell stacks by a very low constant current charger (24v 4Amp lead acid charger)
SparWeb:
Thanks for the confirmation.
That helps me see the picture.
Any company that makes battery stacks like these ones, with extruded-profile cases, 19-inch rack mounting, Aerospace standard power receptacles, day-glow high-voltage power cables, and military circular connectors, has really screwed the pooch when they also have wires slipping in and out of the cooling vents, crimp-spliced to heating pads.
Did somebody say "last minute change in engineering"!?
XeonPony:
--- Quote from: SparWeb on June 20, 2023, 09:52:56 PM ---Thanks for the confirmation.
--- End quote ---
and uses two small course thread screws into the phenolic resin to retain the DC- cables!
Top shelf components, bottom shelf assembly in a lot of areas, the connectors are bolted! so easy to re task for your own stuff.
12v and 24v DC-DC converters too!  400 dollar contractors! good grab bag of goodies
XeonPony:
https://www.ebay.ca/itm/155239081667?    < BMS I got for doing 48V
https://www.ebay.ca/itm/403912335120?    < BMS for 25V
I'd recommend getting the touch screen with it, far more useful to get stats with out needing phone
if you get the battery any ways
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
