Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Wind
report KD 727 about the 4-bladed VIRYA-12 availabel
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: report KD 727 about the 4-bladed VIRYA-12 availabel (Read 925 times)
Adriaan Kragten
Hero Member
Country:
on:
October 16, 2021, 11:07:58 AM »
Report KD 727 can be copied for free from my website:
www.kdwindturbines.nl
at the menu KD-reports. The title of this report is: "Calculations executed for the 4-bladed rotor of the VIRYA-12 windmill (lambda design = 5) with the pendulum safety system with a torsion spring connected to a PM-generator made from an asynchronous motor frame size 355".
This rotor has a very low noise level because it has wooden blades and a rather low design tip speed ratio of 5. The visual acceptance might be large because it has four blades, just as a traditional Dutch windmill.
Logged
https://kdwindturbines.nl
Adriaan Kragten
Hero Member
Country:
Re: report KD 727 about the 4-bladed VIRYA-12 availabel
Reply #1 on:
December 24, 2022, 06:18:55 AM »
A new chapter 9 has been added to report KD 727 about the VIRYA-12. The title of this chapter is: "Ideas about a real 60-pole PM-generator". The advantage of a 60-pole generator is that the frequency is much higher than that of the 6-pole or 12-pole generator as described in chapter 8. This enormous generator is based on the largest standard asynchronous motor frame size IEC 355L.
Logged
Adriaan Kragten
Hero Member
Country:
Reply #2 on:
December 31, 2022, 05:37:41 AM »
A new chapter 10 has been added to report KD 727 about the VIRYA-12. The title of this new chapter is: "Ideas about other PM-generators with a high pole number". The pole numbers described are 64, 68, 70, 74 and 76 for a stator with 72 slots.
Logged
Adriaan Kragten
Hero Member
Country:
Reply #3 on:
September 18, 2023, 06:29:08 AM »
A new chapter 11 has been added to report KD 727 about the 4-bladed VIRYA-12. The title of this chapter is: "Use of a PM-generator of Hefei Top Grand type PMG900-I-30KW-100R". This generator is also used in the 3-bladed VIRYA-14 as described in report KD 732.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Wind
