Steam Engines > Steam engines
4 cycle steam engine
JW:
--- Quote from: MattM ---Can you flash steam with compression alone?
--- End quote ---
No something called "block heating" is considered. Also the surface area of the cylinder piston and bore is insufficient. So one half is traveling balance into the other, so there is a yield consideration. The compression stroke referred to frequential block heating.
I have run "2 Cycle engines" when using 2400psi Argon charge. Ice formed on the cylinder fins. With a OTTO cycle there is a compression stroke this heats the cylinder block and the engine runs better and longer.
JW
JW:
Check this out-
//www.youtube.com/watch?v=W9H5NXdSM5g
there is another video where I make partial revolutions using steam. but the above video is using Argon at 2400psi.
JW:
2639
Navigation
[0] Message Index
[*] Previous page
Go to full version
