So gang. first most please accept my humble apologies for being stubborn.
It is one of those self defense mechanisms that kick in when information gets too difficult for me to process in a, for me, suitable time frame so I just default back to where I was.
It is nothing personal nor will it ever be.
So here is my update thus far.
!!If at any time someone feels I should demonstrate because something does not make sense then please do so to signal that. Because then I will and maybe we find I blundered again.
If it all makes sense to you then I am also content to just go with this flow!!
Context: 300mm radius ID of magnets spaced at a 3.75 degree interval.
Considering non stacked (traditionally spaced with an air gap of around 20mm (4 times that of the magnet thickness) 24 coils per phase) coils even though wider of nature than stacked coils will need about 280 winds to end up in the 2.something volts sphere.
While when stacking coils (48 per phase) in this context only needs coils to be 50 winds to end up in the 1.something sphere of volts.
And I think I can explain why.
You see magnetic fields when induced by electromagnets (the coils) they do interfere with each other. But then in a good way. In where overlapping phases compound.
And here comes the kicker!! The adjacent pole in the same phase does not counteract the other. Not al all!
I just love magnetic fields soo much
If only I understood them
Overmore the field around said coils is non biased for direction. It is a sphere so that means that my earlier worry of having tilted coils would harm the interaction with the magnets seems debunked.
But I know for sure once I start the torque tests. Now I am still in the finding out what configuration actually stands a chance of getting where I need to get.
Anyway all this has set me back on track with the original plan to go for a large diameter. a 300mm
ID {1}inner radius{/1}was just to see. Now I have seen and I can tell. Nah that diameter will never work for my goals of having 52vAC at 3.7Hz (yes it is 3.7Hz not 3.8Hz like I have been mentioning earlier)
Also Ed, You know that I love you so that is why I have not send back the 16 magnets yet. I will keep them ready and waiting so that later on once I have some real life data I can setup a gear ratio to have this suggested setup spin around 20 times faster than what I am making. Just to compare results.
In case my configuration lacks behind then we have a clear indication why not to go with a direct drive for a low RPM VAWT.
I have more to say but no time to write it now.
