View full version: Wind
  1. stator failure
  2. Anyone have any Calculations for tower guy wire loading ?
  3. Otherpower adventures near Detroit MI, Part 2 ~ EMU
  4. MOVED: air transportation of neodymium magnets
  5. Air Industrial 303 parts
  6. #22 gauge magnet wire
  7. Found a problem with my ac voltage
  8. Question : How do I convert an Induction Motor into a Generator?
  9. Database for working turbines
  10. First wind turbine, suggestions?
  11. Need Help Designing a PMA the size of a Skateboard Wheel
  12. Odd idea- would it /could it work?
  13. ebmpapst fan motor
  14. Oversized rotors for low-mid range power, limiting high rpm
  15. Using rope to unwind the pendant cable?
  16. 17 footer...I'm impressed!
  17. Protecting coils on Bergey 1KW
  18. Ferrite core coils
  19. Lamiate Cores - Why Not?
  20. Multiple wind turbines on one tower
  21. Anyone able to produce a 3D cad/CNC file of a 5.3mt dia blade for me ?
  22. Splicing a coil , ???
  23. 17 footer's please chime in
  24. Rare earth magnets
  25. Large diameter magnet rotors.
  26. No tower for power?
  27. And Another VAWT Idea . . .
  28. tail furling device
  29. Is this kWh guesstimator reaosnably accurate?
  30. Stator Winding Temp under load
  31. 11 Blade Rotor
  32. Help for newbie re MMPT and inverter choice
  33. MOVED: Future energy PMG.
  34. Rectifier for grid connect
  35. How much weight have you used to successfully balance blades?
  36. Question for everyone...
  37. setting the mppt for a 4.2 wind Aurora inverter
  38. Magnet Size and wire gauge questions
  39. Baldor cdp3455 for wind power
  40. Poco dinero please check your PMs
  41. Blade Direction
  42. Towers
  43. Planning second build!
  44. just noticed something worrying
  45. Using a Trolling motor
  46. 3d blade drawings for cnc router
  47. servo motor blades
  48. calculating power drop from turbine location
  49. Tails of a wind turbine
  50. Torque Sensing Variable Pitch Hub Designs
