Homebrewed Electricity
» Controls
View full version:
Controls
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
understanding transformers
Will this solar CC work for my new wind system?
turnigy/doc wattson cumulative readings
Controller questions
DR2412 Fan runs all the time
Battery bank A to battery bank B - auto switching
Diversion load settings
Battery voltage? Blow inverter?
Bypassing FM 80
12/24 Volt Hybrid
controller for panel
12volt Photo Cell ?
linear actuators sources
Welder-inverter issue
Measuring DC current out of a battery charger with a 500A 100mV shunt
Measuring Current in a Datalogger - shunts and amplifiers etc.
been awhile, checkin in
lead free solder?
Commanda's Buck and Ghurd's Dump
magic smoke from inverter
UPS as inverter - sources, models, fix for high stby? - bob g, scottsAI, others?
Regulator design help.
DIY AVR/Inverter for a 2600W KIPOR Generator
Oops
off grid system
( Tom's) Fire Emitting Transistor (Magic smoke incident)
Push-Pull Forwarding Converter for Solar
MOVED: SkyRc MET0C100 Watt Meter
One, two or three grid tied inverters? Help please!
Charge controller #2
Primitive (aka CHEAP) buck converter for solar...
Temperature compensation at discharge
AC to DC Pump Step Down Details
How to stablize battery voltage
Ground Fault
Generator breaker tripping - Xantrex charger at fault?
inverters
1st ghurd controller built...
ammeter shunts
connection help
solar converters LDR 96-15DL Dump Load Controller
Wireless communication with aMagnetek - Aurora - Power One inverter
What to do with inverter parts?
Ghurd controller help with zm 33064...
Lightning protection
Grid Tie inverter, 1kW, USA
Remote Control for Inverter
wiring Transfer switch to 110v inverter
Handheld scope recommendations
9v dc from 48v dc to power digital power meter
