View full version: Polls
« 1 2 3 4 5 »
  1. Should they go for it anyway?
  2. How mush do you think the flywheel will weigh
  3. What size Battery and Solar Panel needed to reliably run a RedRock Tracker
  4. Is this a good idea and would you be willing to participate?
  5. Making your own solar panel is:
  6. how many of our friends ride a bicycle?
  7. Buy an Air X or build one from scratch?
  8. How's my turbine for a first try?
  9. Can U do a standard 30-10 prototype?
  10. How much of your daily power needs comes from renewable energy?
  11. What have you done today that is GREEN?
  12. Which resin is best?
  13. Is this project feasible?
  14. Do you think a 12V outboard motor will work well as a wind generator?
  15. Do you like this resource?
  16. Do you like this resource?
  17. What field of RE are you most interested in?
  18. What is Branson's offer?
  19. No Confidence or Confidence in TomW continuing as editor....
  20. Any suggestions would help
  21. Visually speaking, what do you think?
  22. How much of your alternative energy system is (or will be) owner designed and built?
  23. Did the Denver news station do a decent job on the RE issue?
  24. Do you think global warming is real?
  25. Would you ever buy an import wind generator from China?
  26. Do you think backyard windpower is the most appropriate solution to your energy needs.
  27. Do you think BT is a bit of a nut for bicycles these days?
  28. how to search for optimum design of cross flow turbine
  29. Is Solar Synapse the Cure for Power Overload?
  30. Is Solar Synapse the cure for Power Overload?
  31. would you carve your own props if you could unplug from the grid for less than $2000
  32. Do, you feel the editors are getting too restrictive?
  33. Have You Built a Wind Generator ?
  34. AGE/ COUNTRY/YOUR NAME
  35. Do you think it will work?
  36. do you think I can use a wind system with such high winds?
  37. How many solar panels have you built?
  38. How much would you pay for one?
  39. Which site?
  40. What System Voltage Do you Have ?
  41. What do you think of my solar garage?
  42. how do you use a small PMG to energize an Induction Motor to use as a generator.
  43. Should world see more new low tech stuff ?
  44. Which System
  45. Tach's on WindMills
  46. In an hour, my Stirling puts out...
  47. Did this explaination help illustrate the difference between star and delta wiring?
  48. Do you need off grid satellite Internet and/or VoIP communications?
  49. bearings in YAW
  50. Does this kind of theoretical musing belong to this area ?
