View full version: User Diaries
  1. Tape drive try
  2. Inverter back in business
  3. I think I'm on the right track now
  4. New solar system finished!
  5. Stepper turbine
  6. 1/3hp ECM Conversion
  7. Found some turbine blades
  8. The charge counting controller is up and running
  9. 10' axial flux home made windmill -update-
  10. Made a very good decision!
  11. Conversion flys again
  12. Single Rotor Generator Testing
  13. The new mast is up - repost
  14. My first try at FEMM
  15. A good day
  16. Bathurst cottage
  17. first wind mill
  18. A suggestion of "G83-lite"
  19. ash&mills
  20. so far I still working on things
  21. 7.5 hp conversion questions
  22. Semi-Invisible Downwind mini-turbine
  23. Low Wind Beauty
  24. Lighting fixtures adapted
  25. New washer/dryer arrives in the next couple of hours
  26. Increasing autostart charging amps
  27. New 12 Volt Power Distribution Panel
  28. Solar install progression
  29. xkcd :)
  30. Two steps forward
  31. Cleaned up a Little bit.
  32. Spring is on the way ....
  33. Cheap Fast Solar Air Heater
  34. Monitoring GB grid carbon-intensity in real time
  35. Another motor conversion
  36. Fabrication techniques on the cheap...
  37. Low Tech steam pressure capacitator and heater ?
  38. 99V Ametek on E-Bay
  39. Laughed my way threw the whole thing!
  40. A day at the fair
  41. Up and running
  42. The cost of water and washing....
  43. Boone Pickets and his plan
  44. Off topic - Those interested in preserving freedom..
  45. Looking for home energy audit people in the UK
  46. Pictures of a tower that I'd like to use for a turbine...
  47. Windows
  48. Energy Conservation
  49. Statistics look discouraging
  50. Put her back up!
