View full version: Other
« 1 2 3 4 5 6 »
  1. Lightening?
  2. How does this dynamo work????
  3. generator problems
  4. MOVED: Gravity is a valid power source so why not use it
  5. MOVED: Generating electricity using gravity
  6. Trying to use a GE ECM motor as a bicycle powered generator
  7. recycled generator
  8. Lister 16/1 48VDC Battery Charging
  9. DIY Organic Rankine Cycle engine
  10. Magnic Lite
  11. Harvesting Eddy currents - but how??
  12. Help needed on charging a battery
  13. hacked PC powersupplies
  14. Tawasi ST-15 parts
  15. DIY demagnetizing tool
  16. Steam power
  17. HandGen - Mk1
  18. UPDATED LISTER 6/1
  19. New alloy converts heat directly into electricity
  20. What size gas generator do I need for my boat?
  21. PM armature alternator
  22. My latest project
  23. HELP!! Generators control box had electrical fire!
  24. Sterling Low temp engine on a roof
  25. Stirling Engine Video from WXYZCIENCE
  26. trifilar coils?
  27. bates car, sweet as a nut
  28. Need search help
  29. Induction motor to generator
  30. New Quantum levitation Video
  31. Removing shaft key from servo motor shaft
  32. Stirling Heat Engine
  33. WYE, DELTA
  34. motor conversion help
  35. Kohler 18.5 KW diesel
  36. Making/using WVO
  37. The SwingGenny revisited
  38. Small Biodiesel Maker
  39. Antique Dynamo Help
  40. Stirling power?
  41. water injected steam engine
  42. Heat Source for Biogas Digester
  43. DIY OIL WATER HEATER
  44. Magnets and the curiosities I have about them
  45. Best shape for fresnel lens...square or rectangular?
  46. Backup generator size
  47. Re: Posting Guidelines
  48. Pedal Power station V2 Begins
  49. DIY Wooden EPDM Hot Water Storage Tank
  50. Some body went Big
