Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
oem wind power
How big a mill can my tower hold?
smaller neodymium magnets
modify dc radial winding
BROKEN
Rutland 913 stripped down - bearing replacement video.
New wind generator flying. "Big 5"
Galvanized 4" Pipe Tower
Connecting Multiple Ginnys
Stator thickness on new design ??
Square vs Round Tubing Tower Construction
24 volt wind turbine set up
Fiberglassing blades
17 ft machine furling
Blade balancing question
Aurora GTI residual current and setting questions
Bicycle hub motor as wind generator?
GOE222 /table saw??
Coastal Wind Characteristics
Some advise about a new build please
One single blade ?
ametek 38vdc wind turbine (modified)
MOVED: big turbine on fire
Variable Pitch Hub
would this make an acceptable generator head for a wind turbine?
MOVED: Please explaine 3 phase to dc, I'm lost
simplex mill
Next project well underway.
lightning strike
SW 403 48v back up
Blade root length
VAWT, PMA, stacked stators and rotors
serviced turbine back up and running.
Oops - gone all bendy!!
Anemometer Tower
Maximum blade speed
two types of single phase
An operational VAWT for rural electrification
Relay tied to the grid for easy high amp transfer
Inspeed anemometer kit. anyone use one?
How to size the propeller based on generator specs
Longevity
Ametek Shaft Adapter Removal?
Had some wind today, got good test #s.
Superhydrophobic
Rewinding a Proven stator? Hugh?
machining epoxy
small wind generator with variable pitch blades
Oil bath for wind turbine transmission
Delco PMA testing with caps.
