Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
Portable turbine?
Newbie build. Is this a good motor to start with ?
Low wind chinese turbine options
LG motor conversion
How to build big altenator part2
pouring stators for axial flux turbines
Helping daughter build alternator
Wood is good until .....
What to choose - delta or star??
Which charge controller to choose for Whisper 200 ?
Light Wind Heavy Weight Turbine Project - as I build it.
rotor / stator design
Speed Control methods?
5Kw or 30KW?
axial flux permanent magnet generator
MOVED: Piggott Blades simplification possible?
How to transmit the wind power?
How to build a windometer?
Size limit of air gap alternators?
geared wind turbine or direct drive
Servo Motor Brake Removal
New post need some help 17 ft machine connected to 6 kw aurora inverter grid tie
Math formula calculating number of magnets per coil ratio for a phase
Windtronic BTPS6500 Wind Turbine
What About FLAT or Square Wire for Coils?
ice on blades
Betts Law question.
How to build big generator
more table saw blades
Glass fiber blades vs. wood blades
FreestandingWinchargerTowerAnchorInfoNeeded...
change 3 phase pma 12v to 24v
CENTER A STATOR
Big water-pumping mill
anybody using wood telephone pole tower?
A different wind tubine
charging voltage
What inspired us to make windgenerators
Funny
Ametek 30 VDC motor
Grid Tie. opinions and experiences please
40 mph wind mills??
ewt 500 kw turbine pics
buying blades
12footer Hugh Piggott Stopped ?
CNC Machined vertical wind turbine
DIY axial PMA from free recycled parts.
Highly restrictive wind turbine/tower ordinances
DC motor options, please advice in them
individual rectified coil question.
