View full version: Wind
  1. Composites Vs. Wood (blades)
  2. ? on Hughs 48" genny.
  3. 3-phase vs. single-phase alternator
  4. questions from a newcomer
  5. Magnet wire?
  6. low output new dual axial alternator
  7. I'm impressed
  8. Planning my next Wind turbine
  9. Muffin Fan, how to open, pics
  10. savonius turbine
  11. How many mags and coils for this?
  12. RPM for a jenny of 5 ms
  13. Blade extensions - would you even want them?
  14. Starting from Scratch
  15. New mill, Is it AC or DC power
  16. Conversion VRS Dual rotor?
  17. Tower ?
  18. Thermor Weather station problem
  19. Shape of blades?
  20. First test produced 4 volts
  21. induction conversion...
  22. Maximum coil voltage
  23. airfoilprep
  24. New motor driven tail furl
  25. rectifing three phase
  26. Help with Windings
  27. 2 blade /stable?
  28. wind and baseboard heaters
  29. 180v 1.5 hp to 12v charge?
  30. stator help
  31. elec fork lift motors 4 wires?
  32. just on the BBC News
  33. Terra Moya Aqua
  34. Windings, wire diameter & RPMs = volts & amps
  35. blades
  36. New savinous wind turbine...
  37. Copper wire vs Magnet wire
  38. Lost information
  39. Maximum tsr
  40. 2.75 kw bernard generator
  41. Large induction motors for generators?
  42. Composite blades
  43. Waterheating
  44. What kind of wood should I use?
  45. Update on VAWT Model Project
  46. Axial flux RPM?
  47. electronic gizmo
  48. high voltage windmill
  49. 60KW VAWT...request for RFQ
  50. Commercially Manufactured Turbine Blades
