Recent Posts
Pages: Prev 1 2 3 [4] 5 6 ... 10 Next
151
Coil winding / Re: How to determine the limits of a coil / magnet configuration
« Last post by Bruce S on April 01, 2024, 04:24:58 PM »
hahha well that flew back in my face like a boomerang as the iron powdered coil slab kept bending. who would have ever thought that 4.5mm of iron powder filled resin is not rigid enough to not bend with these kinds of fields around them :) ?
So I really have to extend the process now. Going to fill up both coils to 15mm in thickness and then finally be able to make some sense of this iron powder use.
I'm a bit concerned about this. Is the resin actually bending when the magnets swing by it? That could mean a few things.
1) Resin pour was too thin to hold up under the forces
2) Resin wasn't completely dry and allowed the pour to bend
3) wrong type of resin? Most that I've used in the past was 2-part type that once hardened was going anywhere, though I did do a few very thin pours on purpose that would bend.
« Last post by MattM on April 01, 2024, 03:10:51 PM »
I have confidence there will be plenty of electrical harvesting with your 4:1 gear ratio.
153
« Last post by brandnewb on April 01, 2024, 01:21:55 PM »
Ive been following your other blog updates.  I think 0 is go.
{1}dear brother, you know of course I meant all this below in good fun yes?{/1}
hahha why would you respond in such an ambiguous manner when you know you are dealing with the weird mind I have. :)
to me this means either you are waiting for things to lift of at 0 because you already have a sense that we are on the right track
or
yeah no matter what these early results have gotten us thus far. we are still not at 0 yet so only then we will know. and a GO can go horribly wrong as spaceX has been showing us.
you see how life is full of choices? too many I must say.
154
« Last post by MattM on April 01, 2024, 10:52:24 AM »
155
« Last post by brandnewb on April 01, 2024, 09:41:19 AM »
early tests failed hard :( I thought why not only test the central shallow slab with the coils in them of both coils first. They are roughly 4.5mm thickness.
Also I made both slabs 35 winds resulting in a 35 -70 -35 configuration. Please never ask why I went for 36 while in theory 32 should have been enough already!
And you already know that I do not mind if I can not demonstrate anything useful in terms of voltage generation ability. I will also report my failures.
However I still am considering still using this iron powered filled casting just to help the heat dissipation ability.
But now we have another challenge. How can we make sure that the casting process was rigid enough to prevent the 150 um sized particles of powder to stay put. Never move else risk chipping away at the enamel.
I'll be honest. I do not think that any configuration in terms of frequency will ever allow for this powder to allow to chip away at the enamel. Because the particles at ultra high frequencies will just get lazy and do nothing. (please do not trust this to be actual science!! this is just my effort to visualize it for my self)
Now then one, including myself, wonders. Why did coil #1 shorted out in earlier tests then?
hmm
I am still at a loss. Maybe just that coil did not like a massage and then went on strike?
Ahh and here lies the possible answer. I just used too much force during the installation process for it to short out. But truth be told I am no scientist so my own data could contradict my interpretation of said data if I just was good and making sense of all this.
Anyway. All systems go!!!
@MattM. Do you remember the thunderbird countdown?
we are now at 2 seconds before liftoff.
156
« Last post by TechAdmin on March 31, 2024, 04:52:48 PM »
I would like to get notifications again of when I get feed backback on my content. Just like it has been for quite a while before.
Am I unaware of some kind of setting change that I really should be of?
Emails aren't working either, most likely.
157
« Last post by brandnewb on March 31, 2024, 01:45:07 PM »
158
« Last post by brandnewb on March 31, 2024, 12:23:50 PM »
So I think I have figured out a way to really compare apples to apples when it comes to coils in the context of the current dual rotor disk and each having their 96 magnets at a 3.75 degree interval.
And whether adding iron powder does any good in terms permeability of the field between the magnets of the rotor disks and thus will lead to an enhanced voltage generation ability of the coil.
This is my hypothesis. It has been for quite a while.
Now please jump in here and present the possible errors of my plan if you can spot one as consensus is all I care about.
So the idea is to have 2 identical 3 legged serpentine coils of 36 winds. Identical other than one is filled with basic resin and the other is filled with iron powder.
Yet both of them will be squeezed to their absolute minimum. I am guessing something of like 3 to 4mm will remain.
Now we know for sure that all the wires are concentrated on a fairly single plane.
Now we can start adding both sides of both coils with their respective resin composition (without any more wires of course) equally to reach their intended thickness.
The result will be a super thin few mm of wires in the center of the full 15mm coil.
And now, and only if I can make sure that both coils are equally positioned enough between the disks.
Only NOW we can take tests seriously.
Now mind you even the last part is no small feat. But I will get there.
Now before I break my head on actually doing this. Is there anyone that can see an error in the idea? I mean what is the point going through all this trouble if no one will take the data seriously and no one will take my test setup I offer to reproduce said results.
159
Wind / Re: Christmas Windmill Time
« Last post by taylorp035 on March 31, 2024, 09:44:29 AM »
After it's not so windy first run, the 12 magnet configuration with a ~1/8" air gap peaked at 5.27A and 21.4W.  I think this is a pretty good result.
I've now tightened up the air gap another 0.050-0.060", so we shall see how it does.  If it can peak at 6 or 7 amps and 30 watts, I would be happy.
160
Site News / Re: We had a great week!!!!
« Last post by JW on March 29, 2024, 09:10:32 PM »
 XXX
161
Solar / Re: Output of solar panels depending on slope and azimut
« Last post by MattM on March 29, 2024, 02:39:20 PM »
High slope angle also lengthens the life of roof materials.
162
« Last post by Adriaan Kragten on March 29, 2024, 02:26:21 PM »
The calculations of the output have been reviewed because I took a too high peak power of a solar panel size 1 * 1.65 m. The peak power is reduced from 400 W up to 300 W.
Dear Adriaan,
So in general; if one has far too much power generated by the solar panels oriented in a east-west back to back setup in summer times. with as goal generating as much as possible during winter times.
even after you have refined your study a bit based on the new peak values.
Would you still conclude that an optimal south facing orientation of the panels, even though now needing more spacing between rows, will benefit the power generation during winter times?
If that is the case then I need to find some new and inventive ways to reposition more than 22 panels as my roof is already maxed out :( (I now have 44 panels in a east-west back to back configuration)
One thing I have been considering is to have floating arrays of panels. But especially during winter time the sun is rather low so I will need to have them float outside of my property to have full sun. But I guess no one minds as then we have little to no boating activity during those times anyway. But then that damned freezing that could happen. Now I have to think of a raft type that can deal with that.
{1}reason I ask is because I am trying to transition away from grid connected as even though netmetering has been extended for some time by our government again. electrical utility providers are actively trying to circumvent the loss of revenue by employing really nasty tricks like for people with smart meters. Some if not most of them are now being taken from behind by now netmetering will be done on a monthly basis rather than annually.
I am ecstatic I have always resisted the installation of a smart meter. And please believe me they tried! hard!!{/1}
If you want to put solar panels on an existing house you have little choise about the slope and the azimuth. But for as new house or a new solar park, I think it is best if you optimise the positioning for the month December. If the solar panels are grid connected, the fee which you recieve for one kWh is much higher in december than in June. Maximising the output in December means orientation to the south and a large slope of about 60°. My calculations show that then the loss of energy in summer because of the large slope is less than the gain in winter.
Recently a new solar park was made in my town with east west orientation and a slope of 15°. I have calculted that the output in December is only about 10% of the output in June. If all solar panels would be orientated south at a slope of 60°, the output in December is about 1/3 of the output in June and so the grid imbalance is much lower. Another disadvantage of a small slope is the sensibility of damage by hail. Today I read a story that thouthends of solar panels were damaged is Texas by golf ball large pieces of hail. This was not only caused by the small slope but also because of the too small thickness of the panels ralated to the other dimensions.
163
« Last post by JW on March 28, 2024, 08:14:02 PM »
 Ya they slapped me in face again. still working on this.
164
« Last post by JW on March 28, 2024, 06:01:35 PM »
yes give me a minute, im working on this today.
if the site go's down it will be for a short time I have to make a payment to the host. This time it wont be down for last time which was 2 weeks. I will check on the host tomorrow morning I have to make switch with a bank account. Transfer money to the account for this.
165
« Last post by TechAdmin on March 28, 2024, 05:12:53 PM »
Can you please relay to "Seriously hurry the fv(k up", because I have to delete hundreds of thousands of errors everyday due to php version incompatibilities?
166
Logged in diaries / Re: VAWT backyard experiements
« Last post by brandnewb on March 28, 2024, 04:27:02 PM »
also I am going to incorporate a 4 times rotational speed increase.
I really would like to share why but I also would like to test the waters if there are still actually people interested in the why?
167
« Last post by brandnewb on March 28, 2024, 04:21:27 PM »
@JW, are you sure there is no way for us to just lift the limits of this front end and let us use an actual SQL statement?
I am still frustrated by the fact that one of the community posted the very best suggestion on how to deal with the wobbling of a direct drive. It is in your database I KNOW!! But how to retrieve it?
168
User Diaries / Ooops bit of a problem with smart meters
« Last post by tanner0441 on March 28, 2024, 04:17:46 PM »
Hi
I have been bombarded with phone calls and letters telling me their engineers (electrical supply company) will be in my area installing smart meters.
My matra is "I don't want one and I will change supplier if I have to to avoid having one."  If pushed I elaborate that everyone I know who has had one their bills have increased and I already have a power meter monitoring my usage.
Now it transpires that 4 million smart meters in the UK could be faulty and overcharging people and only working in dumb mode. Each meter has a personality module in it, (SIM card type thing.) and your supplier can alter your tariff at will turn you off individually or control the maximum load you can use.. When they're working properly.
There haven't been any updates on the news about what they intend to do about it yet.
Brian
169
« Last post by bigrockcandymountain on March 27, 2024, 05:18:41 PM »
For off grid, as Adriaan pointed out, south facing makes the most sense.  You will never be short on power in June (at our location 50 deg North) but you will be quite short in december, when east and west facing panels make the least amount of power.
For a fixed array, the old rule of thumb is south facing with angle matching your latitude.  That gets you set not bad.
 I find it better to have a 2 position tilt. 65 deg winter 20 deg summer.
Net metered grid tie is a whole different deal, and then the summer output maximising setups might work out better.
170
« Last post by brandnewb on March 27, 2024, 09:53:07 AM »
Regardless, without adjustments for slope the choice is pretty much permanently made at installation.  Moving panels without reroofing is adding holes to the boat.
Nah, I designed and build my home. So in this case restructuring the panels has nothing to do with the structure of roof the (that is in fact not a roof in terms of structure but just another floor) they are situated on. Other than of course the dimensions they allow for panels to be placed on.
But in general terms you might well be correct. And I did ask for an in general response.
171
« Last post by Mary B on March 27, 2024, 09:12:50 AM »
Besides the original devices being rolled out via a discrete Chinese partnership, it sure seems odd the incessant push for these smart meters as they literally made zero impact on the grid.  Your solar panels facing east-west are probably only superior under dynamic loads like net metering, where you would be softening price gouges at peak draws.  But if you are overproducing during the day with a storage system, to cover your night usage, it would seem south facing would be a wise choice.  Regardless, without adjustments for slope the choice is pretty much permanently made at installation.  Moving panels without reroofing is adding holes to the boat.
Smart meters made revenue jump/bills jump because they can measure the power factor all the switch mode supplies put on the grid, old analog meters didn't.
172
« Last post by MattM on March 27, 2024, 07:53:29 AM »
173
« Last post by brandnewb on March 27, 2024, 05:37:58 AM »
Dear Adriaan,
174
« Last post by Adriaan Kragten on March 25, 2024, 02:12:48 PM »
175
« Last post by JW on March 25, 2024, 11:17:28 AM »
OK I have one of the 6 digit pin's. One more and I can hand of the site over to TechAdmin...
176
« Last post by JW on March 25, 2024, 10:56:08 AM »
 No one can upload photos at this time, I'm still working on this. wait for an update.
177
« Last post by JW on March 25, 2024, 10:52:54 AM »
god you guys have no idea how hard it is to configure the back end of our site. 5 or 10 years ago it was way easy. I am still working without damaging anything. you have to be very careful when speaking to the host.
178
« Last post by brandnewb on March 25, 2024, 01:48:27 AM »
31 coil legs?
yes. in a stacked (or twisted) serpentine coil configuration coils share legs.
but I still can't post images so here I go again :(
https://diysolarforum.com/threads/building-the-sickest-%C2%AE-vawt-ever-brilliant-minds-unite-please.31934/post-1044317
it is basically one big 100 winds loop but because it is stacked the central legs will have double the amount of wires. The field in the first and last coil is just as strong as the fields in the central coils even though having only 75% of the wires.
{1}unless I am making a huge blinder again I think this stacked serpentine is far superior to the standard closed loop coils. Just think about it. we get around 200% electromagnetic field (ignoring the wire savings) as opposed to standard closed loop coils. And then the overall reduction in wire length. I mean only properly conducted gravity torque tests can be of help now if we want hard proof.
I for one have made my commitment based on my data. How ever poorly taken. It is almost as if I show sings of faith :) almost! :)
{/1}
179
« Last post by MattM on March 24, 2024, 11:37:07 PM »
31 coil legs?
180
« Last post by TechAdmin on March 24, 2024, 04:42:41 PM »
We don't have actual mentions... *Cough*... Yet. I do hope he sees this :D
181
Storage / Re: Making large PLANTE lead acid Batteries.
« Last post by tanner0441 on March 24, 2024, 02:22:10 PM »
Hi
I have been reading your post and I am impressed with your perseverance. you roll grooves into the plates to increase surface area and give a key for the lead oxides to adhere to, would sand blasting do the same thing? Careful experimenting with pressure and grit size i would imagine give comparable results.
Brian.
182
« Last post by brandnewb on March 24, 2024, 11:54:56 AM »
I can already tell that running 96 magnets at 3.7 Hz at a 3.75 degree spacing per disk. And both disks spaced at 17mm from each other will never get me to where I need to get using 0.71mm diam wires.
You see I can only get 31 coil legs in that space to have 3 phases non overlapped. yes yes yes I abandoned overlapping phases because it just leaves no space for cores and although unconfirmed I now again think it will hinder the field forming abilities of coils.
So either we increase the rotation speed of the PMA or we decrease the wire thickness.
choices choices.
Now here comes the conundrum.
How can a gravity torque test ever be useful if it depends on the field the electromagnets (coils) produce. And that means they need to be rotated over at service speed. Not at all a gravity torque test can ever provide.
Someone like @joestru please get back in here and make some sense out of this all :(
183
« Last post by MattM on March 24, 2024, 09:47:46 AM »
Perhaps you need the equivalent of an expanded steel sheet but in lead?
Or maybe would a steel wool equivalent work better?  Lots of surface area I assume is important, but needs to be decently saturated or permeable by the electrolyte medium.
184
« Last post by clockmanFRA on March 24, 2024, 05:46:21 AM »
New Modern version concept PLANTE.
The PLANTE method forms the lead surface, microscopic level, into a lead dioxide on each charge /discharge.
Subsequent charge /discharge builds up the lead dioxide. 30 to 40 charge/discharges builds sufficient dioxide for the battery to become sufficiently useful for full time use.
However, doing 0.5mm rolled groves into bare 98% pure lead sheet increases the active area of the created lead dioxide by over 100% surface area improvement.
I have, over the decades experimented building 2v lead acid cells. So gained a fair bit of active hands on experience.
Just having a deep grooved lead sheet plates is not helping us achieve a low cost PLANTE battery, so hence me making a judgment of lead sheet thickness for internal strength and support, plus sufficient depth of rolled grooves to form the lead dioxide and offer a larger surface area of the active cell and importantly these groves will hold the active lead dioxide in place.
Again, its getting the variables all to line up to create a cost effective battery that is simple to make by anybody
Eventually our new PLANTE battery will get better and better amp hours and the lead plates slowly all turn to lead dioxide active mush.
In Theory, and others reckon, at my thickness of plates then a 20 year life is expected. Make the lead plated to thick then the dioxide is slower to form.
Again, its the charge rate that is important as the lead dioxide is formed.
Modern IFLA have thick lead matrix plates into which the manufacturers paste the ready formed lead dioxide.
My new modern version of the PLANTE battery won't give the same amp hour output as a IFLA at first.
But because of me doubling the acting surface area of our lead sheet, then amp hour output will be very good compared to a simple standard PLANTE cell.
Modern IFLA thick lead matrix plates for holding the lead dioxide are normally cast formed, so that is just not possible to make simple lead molds for a DIY battery making
Also manufactures hide where and what is actually in the lead dioxide pastes. As i have said before "its chemists delight", and not easy for a DIY build.
Our modern version of the old PLANTE battery dioxide forming and using, should be a big leap forward.
185
« Last post by clockmanFRA on March 23, 2024, 12:20:55 PM »
2.47 is the charge voltage.
What the amps are for the new from of PLANTE battery 2v cell is not yet exactly defined until the cell is forming stage, then the amperage will slowly need to be advanced until around about 30 to 40 charges and discharges, as the lead dioxide is formed on the surface of each of the 12 cells that are in each 2v battery.
Discharge is also not perfectly defined yet.
So a fair bit of testing to do to correctly form a good lead dioxide that holds well in the surface structure.
186
« Last post by MattM on March 23, 2024, 08:20:59 AM »
Sounds pretty interesting.  Are you aiming for trickle charging or do these have a fair rate they can form the oxides?
187
« Last post by JW on March 22, 2024, 07:25:25 PM »
Quote from: TechAdmin
Did you get your 6 digit code yet?
Yes for the hosting, so now the email exists again. Im going to let the dust settle. Now on Monday.
2 set the single PIN it has to be done on an email that verifies origin. things are going good,
188
« Last post by clockmanFRA on March 22, 2024, 05:13:04 PM »
March 2024.
Case design now confirmed.
Insulators and plate seperators now confirmed.
Battery terminals and plate connections now confirmed.
Please find this simple reply regards what’s going on in a 2v cell at the active lead DIOXIDE level for the IFLA and PLante cells.
This will form, after re-editing etc, part of my ‘How to Make a modern Plante 2v 450ah lead acid battery’ book.
I always try to write and explain and show with picks what’s practically going on. I have concerns that some groups are guessing and starting to spout rubbish about the humble 2v lead acid cell, so hopefully my below comments will straighten a few folks out.
........... Each 2v volt cell has a charge and discharge rate and this depends on several factors.
1. The structure of the matrix grid plates and the ratio between the supporting lead that is a basic PLANTE forming, and the composition of the LEAD DIOXIDE that is already made and pasted into the lead matrix that gives a higher Amp Hour holding capacity from the word go.
2. It is very important to recharge and reform the lead oxide at a suitable rate.   Eg, like electroplating, to quick and the plating does not form and adhere well.   The same with lead dioxide, make it efficient and give good ah output, then its short lived. Make the dioxide paste longer lasting but less preforming ah output, and more stable, then welcome to the IFLA as the lead plate matrix is very, very thick and holds the Oxide paste firmly.
BUT excessive constant charge on a individual 2v cell and the lead oxide that is pasted into the grid matrix will be disrupted, especially where it rests in the lead matrix grid, and then the precious lead oxide paste will shed and drop out.
3. With the IFLA batteries the lead matrix grid plates hold the lead dioxide tight, but the lead dioxide is fragile. The lead holding grid it self will also form the correct dioxide over many (over 40) charge recharges, and slowly integrate with the dioxide pastes. BUT CONSTANTLY GETTING THE CHARGE RATE WRONG AND THE PŔECIOUS LEAD DIOXIDE PASTE WILL START SHEDDING as the bond will be broken.
IN CONCLUSION. Some of you are aware of my R&D experiments and builds on a new modern form of the old pure lead PLANTE lead acid 2v 450ah battery. Forming the pure lead sheet surface into a active lead dioxide mush, but making this surface dioxide mush stable and yet giving good AH output rates, is mind boggling, as the variables that require experimentation and calculation are vast.
Oh yea, and these 13 plate 2v PLANTE cells of mine are all designed around a DIY context and constructed with simple tools.
So bear with me guys as i examine and publish a useful definitive practical guide to the humble 2v lead acid cell.
189
« Last post by TechAdmin on March 22, 2024, 04:47:40 PM »
Did you get your 6 digit code yet? ;D :P
* TechAdmin is pouring salt into the wound ;D
190
« Last post by JW on March 22, 2024, 04:03:54 PM »
Ok one step closer will inform as we get to the next one.
191
« Last post by Adriaan Kragten on March 22, 2024, 04:13:16 AM »
I have written a similar note but now about the output in June which can be found at the same place on my website. The curves given in figure 1 of both notes are completely different. With both notes it is now easy to compare the output in December and June. In the second note, I have compared two systems. System 1 has 12, 400 W peak panels in the direction of east and 12 panels in the direction of west at a slope of 15°. System 2 has 24 panels in the direction of south at a slope of 60°. It appears that the gain in December because of the larger slope and the orientation to the south is more than the loss in June.
If the energy is supplied to the grid, energy supplied in the winter is much more valuable than energy supplied in the summer. So the finananciel output for a certain investment in solar panels and inverters is much higher for system 2 than for system 1. A disadvantage of system 2 is that you need a rather large distance in between the rows of panels to prevent that panels come in each others shadow. But if the ground is cheap, system 2 is still a better choice. System 2 also has as advantage that the ratio in between the energy supplied in December and the energy supplied in June is about a factor three higher than for system 1 and so system 2 creates less imbalance in the grid. System 2 also has as advantage that melting snow, leaves and dust are easier removed and so the panels of system 2 need less cleaning. The panels of system 1 are normally laid very close to each other and the ground below the panels will get almost no light and almost nothing will grow there. For system 2, a certain crop can grow in between the panels and so nature is more lively.
192
« Last post by brandnewb on March 21, 2024, 09:57:42 PM »
please accept my humble apologies.
I understand and agree with your assessment.
respect
193
« Last post by TechAdmin on March 21, 2024, 12:31:54 PM »
I agree, please keep politics out of here and go back to coil :D I'm rather looking forward to the end of this thread and some kind of formula/solution discovery.
194
« Last post by JW on March 21, 2024, 12:29:55 PM »
well it is certainly not nonsense but yes I will admit it is of my opinion.
Just look at the differences between the EU and the US in regards of citizen privacy.
https://en.wikipedia.org/wiki/General_Data_Protection_Regulation
your bringing up politics, we don't don't do that here, its one over policy's here. And you are in violation of that here/now.
I cant recommend another website that will accommodate what you are doing here.
This site is purely tech site.
You may have to find another website to post in.
195
« Last post by brandnewb on March 21, 2024, 09:22:54 AM »
But in your defense the rest of the world is, in my opinion, equally behind in protecting us.
Then we have of course the DMA
https://en.wikipedia.org/wiki/Digital_Markets_Act
I have a personal strong benefit by this law as a developer of a mobile application.
For years Apple has thrown sand in our eyes and now, at least in the Eu, they can no longer do so.
So yes it is my opinion that these facts support my earlier made statement :)
196
« Last post by Bruce S on March 21, 2024, 08:27:52 AM »
the US is not known for it's privacy advocating legislation.
This is nonsense!!  AND only your opinion
Wind / Re: H-Darreius wind turbines ( VAWT ) !
« Last post by topspeed on March 21, 2024, 01:20:37 AM »
My suggestion is to use metric as most of the people, even those on the correct side of the pond, have a feeling with that.
For those that do not then indeed there is always google :)
However I advice against google even though I always use their search :(
https://www.omnicalculator.com/conversion/imperial-to-metric-conversion
is what I would recommend if at all trustworthy.
I for one stopped trusting their calculator regarding the VAWT configuration of the wind turbine calculator.
https://www.omnicalculator.com/ecology/wind-turbine
Ok sure, I might just not fully understood how to dial in the numbers yet but to me this is too ambiguous.
Google has tools to change form one to the other...
25.4mm to the inch
2.54 cm per inch
from there it is easy to get feet...
Yes.
I am open to all suggestios...as I was cut short here where I operate.
Thanks I liked the calculators.
198
« Last post by brandnewb on March 20, 2024, 04:23:10 PM »
the US is not known for it's privacy advocating legislation. So maybe I should warn the coils to not go there :)
Anyway. I am zeroing in on results. I could really use some pointers here :)
can I past images again? not even going to try unless told we can.
199
« Last post by brandnewb on March 20, 2024, 11:09:30 AM »
25.4mm to the inch
2.54 cm per inch
Yes.
200
« Last post by XeonPony on March 20, 2024, 08:22:13 AM »
susdesign.com has some great tools for North America on the same topic. I used their tools for slope planning on my rooftop solar.  I also used their overhang calculator to visualize how my overhangs would work on my south facing windows.  They worked out almost perfect.
My slope is 65 degrees in winter and 20 degrees in summer.  The winter should be steeper for good snow shedding.  Otherwise it works out well.
The new panels on the shop are vertical (90 degrees) and do great in the middle of winter.  They wont make much power in june, but we usually have lots that time of year.
If you have a smart phone a great app is Sunontrack, it is a paid app, but has reality augmentation so gives virtual overlay of the sun at various seasons real time.
Used it a fiew times and is pretty accurate, and based on reviews around the globe
