View full version: Wind
  1. Ametek® maintainance
  2. Hdd Magnets and bearings for Generator
  3. Wind Turbine Transmission
  4. Savonius Rahai construction
  5. New Weather Station
  6. Airline delux 6volt
  7. small vortex tabs for more lift at low speed
  8. 7.5 hp induction motor conversion single phase
  9. Brief update on experience in Afghanistan
  10. post pic,s of R.E. projects in wind forum
  11. furling animation
  12. Its back up (mostly!!)
  13. Centrifugal Clutch Brake
  14. Using a stepdown transformer on a turbine
  15. Using an Mppt charge controller on a windblue 540 pma
  16. Protecting inverter from lightning
  17. MOVED: please help me build my own windmill
  18. Our upcoming workshop schedule
  19. new tower!!
  20. 24/48 conversion completed - 16' flying again at 85'
  21. Aurora Grid Tie
  22. 4 ft turbine advise
  23. Datalogger
  24. Total Amperage from Wind Turbine
  25. Speaker/Subwoofer Magnets For Small windmill?
  26. Use 3 phase output vs DC
  27. MOVED: amps calculation help
  28. Vibrations / "wobbling"
  29. My next turbine
  30. Need a push in the right direction
  31. Building wind turbines at Scoraig in May
  32. Which turbine produces more power!
  33. MOVED: Voltage Regulator Circuit needed for a wind turbine
  34. VAWT Swept Area Calculation
  35. Another Will this motor work for a windmill ??
  36. Free Wind Data Logging Software AND ????
  37. cast nylon stator
  38. Resistance added
  39. Anyone got a mathematical model of the load on a winch
  40. coil winder
  41. Airplane vs. Tower (...not as bad as it sounds)
  42. MiniWind RC2200-105 generator.
  43. Hugh's Brakedrum Alternator with Neodymium Magnets
  44. MOVED: 1kW turbine generator
  45. Chosing a generator for a small Savonius rotor.
  46. ametek 38vdc blades
  47. Radial stator backing
  48. Blade profiles, which do you use?
  49. Best coil geometry for round magnets
  50. stator help requrired
