Homebrewed Electricity
» Controls
View full version:
Controls
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
Boost voltage vs. boost rpms
genny control
Transporting 48 volt Dc
controller question
Soladin Inverter in the U.S.?
load control circuits
re inverter dc voltage
Overdumping
Best way to Dump?
oatleyelectronics new controller
voltage mointer design needed
Wiring Gen to Xantrex SW4024 Gen Control
Diversion Load
Grounding an inverter
ford starter solenoid
Looking for a large step-down transformer
Making an alternator
Circuit to harvest Turbine power with Resistive loads
Is this desulfator any good?
500 amp Shunt
Versatile Project Board
discontinuous mode detection
Small Inverters Shutting Down
Battery monitor for caring NiCad/NiFe battery
How critical is Hz?????
Choice of inverter.
switching out high current items
Regulate Voltage without throwing away power
Wire..Stranded or solid?
PV + wind + MPPT setup in Mozda, Gujarat, India
DC Water-Flow Switch Control
diode to batteries
Separate AC inputs
Dump load to charge pressure tank (well)
36 Volts, 96 Volts - Handling odd voltages
Cleaning up output from a modified sine wave inverter
Want to see an ugly sine wave?
New toy. Newbie. Oscilloscope
Need a thermostat, on 32F
charge controller
huge ups
Looking at Charge Controllers
24 VOLT INVERTER
Need to find vibration switch in the US....
a call to show layouts and/or photos of AC/DC power control panels
CHARGER
Battery charge graph
High Voltage Inverter Design with PWM control for battery charger
Inverting en transporting power
Net-Metering Public Policy Research
