View full version: Wind
  1. Ebay Windmills From China ?
  2. TLG-500?
  3. Importance of balancing a Savonius vawt?
  4. ABS Plastic finishing
  5. Foam core fibreglass blades
  6. Tower
  7. New to the board (Long Post)
  8. Wood for blade construction 10'
  9. Stepper gen reborn!
  10. Coil Size for 12-feet wind turbine
  11. real generator efficiency??
  12. No Twist, No Taper
  13. Zephyrus Induction Wind Generator
  14. Torque Motor
  15. Q for DanB
  16. Stator casting - epoxy/polyester/versamid
  17. 20 Kw Commercial wind with axial flux alternator
  18. Axial flux analysis
  19. 180 volt PMDC Stalls
  20. Air Rotor Testing
  21. TDM generator newbie help
  22. ? for DanB?
  23. Construction tail with double attack
  24. Tower Pipe Sizes
  25. Wincharger Air Brake system
  26. Blade Questions
  27. Downwind turbine question
  28. generator calculations
  29. Different Materials
  30. Fiberglass Blades
  31. swept back blades
  32. Looking for workshops
  33. Windmill designs
  34. Has anyone tried a 10Kw Axial?
  35. Big straight line wind or something
  36. 5 foot Composite Plug all sanded
  37. 2 meter Blade Diameter
  38. 84 turns of 3 in hand AWG 20 2sq inch N50 Magnets
  39. Windmill direction
  40. Small turbine ideas
  41. Generator help????
  42. P.V.C - Fibre glass hybrid blades?
  43. Ametek 38VDC Motor
  44. ENERTECH 1800
  45. A little help with my Lakota.......Jerry!!!
  46. vertical axis wind turbine
  47. New Wavt (for me at least)
  48. ... Time to replace the blades and get new storage
  49. Creative Wind Power
  50. DID YOU GUYS SEE THIS LOTS OR SMALL ROTORS
