View full version: Wind
  1. New motor driven tail furl
  2. rectifing three phase
  3. Help with Windings
  4. 2 blade /stable?
  5. wind and baseboard heaters
  6. 180v 1.5 hp to 12v charge?
  7. stator help
  8. elec fork lift motors 4 wires?
  9. just on the BBC News
  10. Terra Moya Aqua
  11. Windings, wire diameter & RPMs = volts & amps
  12. blades
  13. New savinous wind turbine...
  14. Copper wire vs Magnet wire
  15. Lost information
  16. Maximum tsr
  17. 2.75 kw bernard generator
  18. Large induction motors for generators?
  19. Composite blades
  20. Waterheating
  21. What kind of wood should I use?
  22. Update on VAWT Model Project
  23. Axial flux RPM?
  24. electronic gizmo
  25. high voltage windmill
  26. 60KW VAWT...request for RFQ
  27. Commercially Manufactured Turbine Blades
  28. rotor out put and matching generator
  29. Windpower Science Fair Project
  30. Wind tunnel babble...
  31. 36 1x2x1/2 magnets
  32. Homemade tachometer?
  33. Can an 01 Whisper H40 be changed from 24v to 12v or?
  34. Forget the weed -eater
  35. 5--Bladed Turbine..... Why not??
  36. Anyone have info on the Breezy 5.5 homebuilt plans?
  37. new jennys from italy 500 2,4 m e 3,6 m
  38. Looking for Generators for Wind Turbines
  39. It's in the air
  40. First London home wind turbine
  41. Output of this servo motor?
  42. need help with system
  43. 11 inch rotor 8 mags 6 coils
  44. Longest running dual rotor?
  45. design of a savonius generator
  46. VAWT swept area clarification.
  47. What is a good price for magnet wire?
  48. PVC Gutter Blade Pics
  49. Websites with Blade Calculators
  50. Wind Generator Blade Calculations
