Author Topic: step warmfloor  (Read 2804 times)
xhueydriver
step warmfloor
« on: April 19, 2007, 08:32:25 PM »
Hello, I was wondering if anyone had seen or used this product in conjuction with a wind/solar battery bank?  It looks like it might work pretty good.
http://www.warmfloor.com/english/24v.htm
« Last Edit: April 19, 2007, 08:32:25 PM by (unknown) »
drdongle
Re: step warmfloor
« Reply #1 on: April 19, 2007, 04:56:51 PM »
Their not very forth comming with specs, personaly I'd recomend a hydronic system. You can use any heat source with it.
« Last Edit: April 19, 2007, 04:56:51 PM by drdongle »
johnlm
Re: step warmfloor
« Reply #2 on: April 19, 2007, 05:04:23 PM »
In my opinion, unless your heating a very small room or a larger room that is super insulated, using wind generated power for space heating at such a low voltage is not very practical.  The statement "heat your whole house" - with 24V heaters is kind of a nonsense come on.  It might be more practical if you generated higher voltages and strung 24V heaters in series.  For a 24V heater to put out as much heat as a standard 1500 W 120V small space heater it would draw 62.5 amps.  The connecting wire would get costly.
Johnlm
« Last Edit: April 19, 2007, 05:04:23 PM by johnlm »
BigBreaker
Re: step warmfloor
« Reply #3 on: April 20, 2007, 07:56:43 AM »
Completely stupid.
For off-grid RE you heat with heat - IE solar thermal.  Run a solar water heater into your hydronics system.
« Last Edit: April 20, 2007, 07:56:43 AM by BigBreaker »
Re: step warmfloor
« Reply #4 on: April 20, 2007, 04:29:44 PM »
interesting...
The address info given is not 10 miles from my house!
I think I'll take the scooter over and see who & what.
Not the best place in St. Louis, but rent is fairly low so maybe they're there to keep prices low.
The bigBox places are selling warm floor type radiant flooring that goes into the floor, but they use 120Vac and inside the box is where is becomes useable.
I stop in this weekend and see will let you know.
If it is as good as it could be, I would thnk you would need some good sized batts to keep up with the need, but then again if you're home power is out due to storm and this is in and can keep the floor warm from batts and people from freezing? well then it's worth gold.
« Last Edit: April 20, 2007, 04:29:44 PM by Bruce S »
Re: step warmfloor
« Reply #5 on: April 20, 2007, 04:35:00 PM »
Also; If you do a goolge map of the address, the map pics are all wrong, the dirt and stuff is gone and the MetroLink extension is there with nice new buildings:-)
« Last Edit: April 20, 2007, 04:35:00 PM by Bruce S »
turboredcart
Re: step warmfloor
« Reply #6 on: April 22, 2007, 07:51:18 PM »
I never had radiant floor heat- it is supposed to be great.
« Last Edit: April 22, 2007, 07:51:18 PM by turboredcart »
Re: step warmfloor
« Reply #7 on: April 23, 2007, 09:09:18 AM »
Just a quick update. I dovre by Sunday. Wish I had gone there Saturday.
They are a true company , I looked insdie the back window and saw that they seem to have a fairly good stock of supplies. Also saw floor plans so they may be at least a real company. I will later this week stop in and see how much information I can get, will also let them know about this forum so they can answer questions for us.
« Last Edit: April 23, 2007, 09:09:18 AM by Bruce S »
