Going to the stronger magnets could drive the blades into stall. As Flux mentions a wider air gap might be necessary. So why not design the alternator so that you could increase the distance between the rotor and the stator as you see fit. Well, that might be hard to do 50 feet off the ground, but it's a thought. So, you do the testing at ground level.
