Author Topic: Hub pics for Hiker  (Read 814 times)
Hub pics for Hiker
« on: July 27, 2004, 09:17:52 PM »
If these pictures load they are simular to Hikers wood hub. There is also a 3 blade triangle hub with plastic blades. Well here goes?
« Last Edit: July 27, 2004, 09:17:52 PM by (unknown) »
Re: Hub pics for Hiker
« Reply #1 on: July 27, 2004, 10:55:56 PM »
looks great...
i used  a hand saw to cut mine out-and a drill bit at the bottom of each slot..
what type of tool did you use to get that flat bottom in each slot??
« Last Edit: July 27, 2004, 10:55:56 PM by hiker »
« Reply #2 on: July 28, 2004, 01:21:21 AM »
heres a shot of mine--
much to big for the back of my motor  home!!
it was just a test for a geared up alt..
went back to using my single 7 ft. blade..
works great now..once i found out the mounting
hole was drilled at a angle-caused the the mill to
go back and forth--really cranks up now--next i"ll
offset the mount so it will turn out of the wind..
« Last Edit: July 28, 2004, 01:21:21 AM by hiker »
