Sorry to bother you with decogging questions! Am worried about loss of power and having to buy a power file for the decogging as recommended by ecoinn in New Zealand. Suggestion is not to use a file as one will damage the windings. A recent article in "ReNew", an Australian green magazine, mentioned that to ecoinn's knowledge, no one has successfully built a mill without decogging. Decogging gets around 50% to 63% of the initial cog.
Ecoinn has even built a hub that allows an idle spin of 90 degrees before engagement of the alternator takes place to get around the residual cog. If so, I would be very interested to see a sketch or explanation how that is done if someone has built one.
If a mill has been built (decogged or not) I would like to hear which prop then drives it. Is it a Jerry, Hornet, total Alu profile by the meter or the Piggott Peru or Indian profile made out of wood?? And how many blades were used and did it need a furling system as carbon fibre blades seem to take up to 1500 RPM. I am using three bearings on the shaft, two pillow block bearings (25mm inner) which are better than the original 6005 SKF bearings and one 6005 for the rotor. Vibration should not be a problem??
Dominic
