You haven't defined your operating point clearly enough.
If you mean that the avg WS is 12mph, then the wind capacity is only 4.4KW at 100% for an 18 footer like Dave B has built and that isn't big enough.
I you mean the avg WS is 15mph, then the above 18footer will give you 8.6KW at 100%,
so 3KW delivered is possible.
If you mean that the maximum power you will be designing the generator will be 3KW, then you are in the right ballpark.
Caution: a 10 footer is relatively easy to construct and plant on a tower, however an 18footer similar to what I am currently building has a head asssembly that weighs 200+ pounds and that is no toy to get 50+ feet up into the air. Most here will tell you to get your feet wet with a modest unit, and then scale up once the kinks are out.
The current Jacobs 23 footer delivering 3KW at 15mph (rated at 10KW at 25mph) weighs 2500 pounds!!
http://www.windturbine.net/specs.htm
note: In above calculations I am choosing an arbitrary Weibul distribution factor = 2
semi OT ...does anyone have any documentation how they are doing dynamic pitch control (not furling) as in their advertising??
