Sorry if this is in the wrong category.... Working on a PM based wind generator, and I am trying to figure some things out.
I have an Idea how to calculate the voltage of a given winding in a PM based alternator, based on Gauss, distance, rate of change of the field, and number of turns in the winding, but how can one have an idea of the amps that a coil can source (into an Ideal load 1:1 Ohms - source : load, or even to a short circuit (0 ohm) load)?
Obviously, the motive force is a factor, but lets set this as ideal, as in always sufficient to give the stated rate of field change regardless of loading.
Also, of course, the resistance of the coil must be known, but there must be other factors as well?!! What (magnetoinductive) design factors influence this parameter (other than voltage, coil resistance, heat capacity, etc), and how can the ampere sourcing capability of a coil - magnet interaction be estimated?
Any Ideas?
