Unless the inverters were made to be stackable, then I don't think you will get permission to do it.
If you can afford all this equipment then you might consider one big inverter for the solar, and then ask your electric supplier how much it would cost to add a meter just for the mill.
If something goes wrong with one system you still have the other, plus solar and wind are hard to combine like that unless everything goes into batteries and then gets inverted and backfed from there.
The pv system puts out steady dc. A mill doesn't. The voltages won't match either. That's why it difficult to combine the two.
