Author Topic: Cheap CFL;s  (Read 7482 times)
Monzadude
Cheap CFL;s
« on: April 21, 2005, 10:23:18 PM »
 I hope it's OK to post this. I found CFL's for 1 dollar each at Dollarama. I don't work for them or anything. I just thought it was a good price. I don't know who makes them. They just have the Dollarama name on them. They're 11 watts = 60 watts. I bought some to try and they seem to work alright. Maybe not quite as bright as some of the brand name ones I have but still pretty good. I realized that I still hadn't changed the bulb in my daughters room so I replaced the 100 watt bulb with one of these.( come to think of it, maybe that's why it didn't seem as bright) The very next day she turned her light on in the morning and forgot it was on. Good timing on her part. I hope this helps some of you. CFL's are great. CFL's for $1 is even better. :-)
Bill
« Last Edit: April 21, 2005, 10:23:18 PM by (unknown) »
pyrocasto
Re: Cheap CFL;s
« Reply #1 on: April 21, 2005, 04:40:38 PM »
I saw some for $2-3 at a flea market, but they didnt have the hours on them so I didnt try. I'm afraid to buy some that might go out in a few hours.
BTW, is dollarrom a local store or is it online?
« Last Edit: April 21, 2005, 04:40:38 PM by pyrocasto »
Big All
Re: Cheap CFL;s
« Reply #2 on: April 21, 2005, 05:22:26 PM »
I've also bought some 11W CFL's from a local dollar store, work great but the color is a little too blue.
« Last Edit: April 21, 2005, 05:22:26 PM by Big All »
Monzadude
Re: Cheap CFL;s
« Reply #3 on: April 21, 2005, 05:48:33 PM »
It's just a dollar store chain. Maybe only in Canada I'm not sure.
These start a little yellow but after 20-30 seconds it's nice and white. It's barely noticable. It says it's rated for 6000 hrs.
« Last Edit: April 21, 2005, 05:48:33 PM by Monzadude »
doceanboy
Re: Cheap CFL;s
« Reply #4 on: April 21, 2005, 06:01:27 PM »
What name brand?
The reason I ask is Walmart recalled some this year "Globe" I had to return 5 sets....
« Last Edit: April 21, 2005, 06:01:27 PM by doceanboy »
DanG
Re: Cheap CFL;s
« Reply #5 on: April 21, 2005, 06:20:32 PM »
I just had a wall-mart $5 13w CFL die in 3 weeks - I try to avoid Lights Of America brand but I needed the bulb right away and then it wasn't worth a special trip to return it so wal-mart won again - it may get remembered next trip.
I've spent bunches of hundred dollars at this store for workshop lighting.
CFLs 2700; 3500; 4100; 5100; 6500 Kelvin from 4 to 105 watts.
$30USD minimum order - $9.50 flat shipping most orders
Cheapest items are case or 10 piece lots.
CFL's warrantied 12 to 15 months from invoice (letsee Dollarama do that)
16w warm-white reflector for $3.49, or $95 for case of 48.
http://www.1000bulbs.com/product.php?product=9355
105w broad spectrum 5000 Kelvin 7000 lumen for $25
http://www.1000bulbs.com/product.php?product=9185
That 105w medium base CFL has 7000 lumen output!
« Last Edit: April 21, 2005, 06:20:32 PM by DanG »
Re: Cheap CFL;s
« Reply #6 on: April 22, 2005, 06:58:53 AM »
I have not got any that "are in use" for a year or more,
But I always prefered the LOA brand.
Maybe they went down hill?
Picked up some 'Commercial Electric' brand at Home Depot.
Mini spiral. Rated 13w (60w application, AND 13w=52w), 750 lumens,
6000 hours, 5 year guaranteed (at 4 hours per day).
Have one in a light that is rarely used, seems fine.
Four pack, $4.50.
Bought 5 packs.
Thats 100 years at 4 hours a day.
« Last Edit: April 22, 2005, 06:58:53 AM by ghurd »
DERFMOOSE
Re: Cheap CFL;s
« Reply #7 on: April 22, 2005, 07:34:35 AM »
I boughtsome of these from Buck or Two for $2.00 cdn
they lasted about six months in the one use it is on 24/7
  They worked out the same as puting incadesent in so any
energy i saved it was worth the 2 bucks
« Last Edit: April 22, 2005, 07:34:35 AM by DERFMOOSE »
Re: Cheap CFL;s
« Reply #8 on: April 22, 2005, 08:19:37 AM »
Some other cheap ones I had got HOT.
They did OK in open lamps.
But they cooked themselves in an inverted shade fixture
without much circulation.
« Last Edit: April 22, 2005, 08:19:37 AM by ghurd »
Re: Cheap CFL;s
« Reply #9 on: April 22, 2005, 09:56:46 AM »
I may try out your links, still a bit more expensive than $1 though.
Pretty sure Dollarama has stores somewhere around me. We have alot of $1 type shopes in various areas I go to.
If there is alot of interest in these I could see if I can get them cheaper wholesale also. I never started the store but I had found lots of places and things to buy when I had though of opening my own Everythng $1 type store.
Depending where they come from I may be able to do volume type deals for anyone needing alot of them. Not enough saving though to be worth 1 or 2 and cost too much after adding any shipping also. But if there is an entrest in volumes once you see if they are good then let me know.
If I find them in a $1 shop here I will try them myself of course.
« Last Edit: April 22, 2005, 09:56:46 AM by nothing to lose »
Re: Cheap CFL;s
« Reply #10 on: April 22, 2005, 10:11:26 AM »
Are we talking just tubes, or a complete small fixture? Or screw in type?
"I realized that I still hadn't changed the bulb in my daughters room so I replaced the 100 watt bulb with one of these."
I can get tubes lots of places for about $1, Screw types are alot higher maybe $3, and small fixtures I think I found for around $5, so I could expect any of the 3 at a dollar shop.
Heck I love $1 shops, I have bought $10 packs of paper for only $1 or 100 packs for $90, 1000 packs even less per pack. These retailed for $10 in normal stores!
  I have a wholesale account with one I buy so much from them at times :)
  Just because it's only $1 don't always mean it is cheap stuff!
« Last Edit: April 22, 2005, 10:11:26 AM by nothing to lose »
pyrocasto
Re: Cheap CFL;s
« Reply #11 on: April 22, 2005, 12:02:30 PM »
"Just because it's only $1 don't always mean it is cheap stuff!"
But sometimes it does, so you have to be careful. Just like the staples brand paper is noticable crappier than HP brand.(I still buy the staples brand though ;-) ).
« Last Edit: April 22, 2005, 12:02:30 PM by pyrocasto »
Re: Cheap CFL;s
« Reply #12 on: April 22, 2005, 01:44:46 PM »
You have a point there, I meant though the $1 shops sometimes do have good stuff.
Depends alot on the store maybe too.
I got Crayola sparkle paper and sticker paper $1 a pack each (less actaully wholesale)
and lots of greating card and photo paper packs also, name brand stuff. Checking the retail it was about $10 around normal stores and online for the same thing when I could find it.
I think some of what they sell is good closeouts or over stocks often, then they have the everyday stuff that is cheap junk too of course.
Sometimes I just can't see how they can do it on some items. I bought some dolls once, took all they had, several cases. Went to an outdoor flea market (I had other stuff I needed to sell) and had one sitting out with no price on it. When people asked what I wanted for it, I asked what they wanted to pay, I thought it was fair to just take what they offered. Normally $10 :)
They would look at the ones in the cases and pick one out.
 Then when I was ready to leave after the weekend another vendor asked if I would sell them to him, so I did, $5 each he took all.
 Weeks later I was there walking around, and he had a couple out with $15 price tags, he asked if I had more he could buy.
How/why they were $1 and at an Everything $1 type store I'll never know.
 That was probably the best deal I ever found there, but I often find similar good deals, just not that good.
That's kinda a hobby of mine, but I have not had time for it for a long time now.
« Last Edit: April 22, 2005, 01:44:46 PM by nothing to lose »
pyrocasto
Re: Cheap CFL;s
« Reply #13 on: April 22, 2005, 02:13:13 PM »
I just got back from mine, and realized it quite sucks. I'll find a good one sometime.
I also cant find a motor/motor rewind shop within a few hours from here...
« Last Edit: April 22, 2005, 02:13:13 PM by pyrocasto »
DanG
Re: Cheap CFL;s
« Reply #14 on: April 22, 2005, 05:19:03 PM »
Letsee - forgot to mention where I live it's illegal to discard fluroescents in standard refuse bins, keep mercury out of groundwater and all that. If you can find a $1-per-tube recycler they tack on a $3.57 flat fee for handling them, or want $2.50 each for disposal. So just I'm just not nailing a good warranty deal, cost me $17 just to drop off bulbs last project I had going. Same price 8w or 80w per piece. Oh yeah, also no 7% sales tax on internet purchase either...
In the early days even Sony had their own line of CFL's - there are still 3 from 1986 burning back east on an old neighbors porch when they get out there in the summertime. CFL's would go for $35 and weigh a pound each. This is the time I got wary of LOA (CommercialElectric?) when they started selling knock-offs that were pretty lame.
« Last Edit: April 22, 2005, 05:19:03 PM by DanG »
Drives
Re: Cheap CFL;s
« Reply #15 on: April 22, 2005, 07:55:24 PM »
http://www.easa.com
Click find a member, they may have a motor rewind shop in your local area.
« Last Edit: April 22, 2005, 07:55:24 PM by Drives »
pyrocasto
Re: Cheap CFL;s
« Reply #16 on: April 22, 2005, 09:56:03 PM »
someone just told me about a shop near me and it was on that list. Thanks, since now I have the address and phone #. :)
« Last Edit: April 22, 2005, 09:56:03 PM by pyrocasto »
Re: Cheap CFL;s
« Reply #17 on: April 23, 2005, 07:30:10 AM »
Motor rewind shop here wanted $250 to rewind a 4 pound 1/30HP.
Not a full blown rewind, just putting in 4 or 6 coils!!!
All of a sudden I think I can do it.
« Last Edit: April 23, 2005, 07:30:10 AM by ghurd »
pyrocasto
Re: Cheap CFL;s
« Reply #18 on: April 23, 2005, 03:59:27 PM »
I guess I'll try the dump for microwaves and such for wire and mags. Just got a couple cheapo CFLs today, and they are extremely blue compared to my other ones. They remind me of a white LED.
« Last Edit: April 23, 2005, 03:59:27 PM by pyrocasto »
Re: Cheap CFL;s
« Reply #19 on: April 23, 2005, 05:06:32 PM »
How much does that motor cost new?? Is it some specail oddball type or something??
$250, yep I think I could too, even if it took me a few tries and some wasted wire.
I have trouble seeing wires inside motors. I thought of an old guy I new long ago though. He did many things really well that were very hard to see and do for people with perfect eyes. He was totaly blind!
 He could not paint a car, but he could straighten a body better than some guys with good vision.
 Maybe I should close my eyes and work by feel like he did, trying to see something I cannot see well anyway is probably a distraction.
« Last Edit: April 23, 2005, 05:06:32 PM by nothing to lose »
Re: Cheap CFL;s
« Reply #20 on: April 23, 2005, 05:10:41 PM »
Getting to be too many $1 shop chains!
I was at the nearest one today, ya all junk nothing very good!
Was looking for the lights and a meter from a different post to make a counter from. Nothing there at this one.
« Last Edit: April 23, 2005, 05:10:41 PM by nothing to lose »
Re: Cheap CFL;s
« Reply #21 on: April 23, 2005, 06:17:39 PM »
A very average motor. 110VAC, 1/30th hp, 1750rpm, nice bearings,
comes with a big $4 cap.
About a billion turns of 30ga.
Brand spanking new, $3.50!
« Last Edit: April 23, 2005, 06:17:39 PM by ghurd »
Peppyy
Re: Cheap CFL;s
« Reply #22 on: April 23, 2005, 07:50:14 PM »
We have 3 dollar stores in the "City". 2 are the same and one is another chain. I find that if you use some common sence and have an idea of what the stuff costs in a real store you can find some good stuff. On ocassion you might even find something you can't live without.
One had the 2 pin halogen 50w lamps in a 2 pack. I got 2 12-packs of vermont american robertson bits. Some REALLY nice industrial jigsaw blades in 2-packs. Wish I had bought more of those.
I would definatly buy a couple cfl lamps if they had them. The thing that always gets me is if I don't buy all of those one time type items that I want the first time I see them, they will be gone next time.
« Last Edit: April 23, 2005, 07:50:14 PM by Peppyy »
Re: Cheap CFL;s
« Reply #23 on: April 23, 2005, 10:48:24 PM »
"The thing that always gets me is if I don't buy all of those one time type items that I want the first time I see them, they will be gone next time."
Yes me too!
The good stores are about 150 miles from me or a little further. SO I go to the city for important things and find some good stuff at the dollar stores while there. Now often I am not sure of the quality of the item, so I only get 2 or 3, then I find they are great, go back next week to grab a ton, and they are gone!
Hey just thought, Dollarama! Look in the grocery stores too, some are getting into dollar item sections in the stores, I need to check the local food store I shop at, they carry the stuff. Mostly the junk, but sometimes a item, maybe they have the stuff I was looking for here in town?? I think a few carded itmes were marked Dollarama too.
« Last Edit: April 23, 2005, 10:48:24 PM by nothing to lose »
Re: Cheap CFL;s
« Reply #24 on: April 23, 2005, 10:54:21 PM »
"Brand spanking new, $3.50!"
$250 for a rewind :)
Well you know what they say, rebuilt is better than used or new because the problems have been found and can be corrected for. :)
« Last Edit: April 23, 2005, 10:54:21 PM by nothing to lose »
whatsnext
Re: Cheap CFL;s
« Reply #25 on: June 08, 2005, 12:05:51 PM »
I've got a LOA 13watt twister that been on 24-7 as a porch light for three and a half years and still looking good. I like the cooler color.
John.........
« Last Edit: June 08, 2005, 12:05:51 PM by whatsnext »
