Author Topic: 12 VDC car headlight bulbs for light  (Read 8537 times)
Clide
« on: September 27, 2005, 06:45:28 PM »
I started out with taillight bulbs with the high and low filaments and burning the high was good enough for reading. A 60 watt commercial lightbulb is about the largest 12 volt lightbulb one can buy and it's not bright enough for me now. For better light the only answer I've found is car headlight replacement bulbs (the old complete headlights work ok). A $1 shiny SS frying pan for a reflector and 65 watt filaments over the desk are ok and I've seen Xenon bulbs that are advertised equivalent to 100 watts at WalMart so I'll try them next. Is there anything brighter for 12 VDC?
« Last Edit: September 27, 2005, 06:45:28 PM by (unknown) »
crashk6
Re: 12 VDC car headlight bulbs for light
« Reply #1 on: September 27, 2005, 02:16:09 PM »
WOW, this takes me back to the EARLY days of RE... kind of a nostalgic pioneering spirit... and... a creepy make it all go away feeling! I won't give up my compact fluorescent, LED's, and modern low voltage electronics for anything! We have made some definite improvements since the days of headlights 12 volt car appliances and home brew bailing wire resistors! Granted some things still have there place, but headlights are energy hungry little buggers just like any incandescent bulb.
crashK6
« Last Edit: September 27, 2005, 02:16:09 PM by crashk6 »
crashk6
« Reply #2 on: September 27, 2005, 02:31:53 PM »
Good heavens, I forgot to tell you where to get nice bright 12 volt CFs! Go to http://www.naturallighting.com
Contact them via phone, they can put a 12 Volt ballast on most any of their CF bulbs... Their 13 watt is roughly equal to a standard 60 watt bulb. They make up to a 105 watt CF, I don't recall the lumen equivalency to is incandescent counter part but I have used 105 Watt fluorescent as yard lights. So that gives you a good lead.
Now keep in mind our hosts provide 13 watt CFs in 12 volt as well... although you did say you needed more light than an equivalent 60 watt incandescent can offer..
crashK6
« Last Edit: September 27, 2005, 02:31:53 PM by crashk6 »
ruddycrazy
« Reply #3 on: September 27, 2005, 05:19:37 PM »
Hiya, Why don't you try the 1 watt luxeon star led's, or even the 3 watt ones. They run only only 3.6 volts and the 1 watt runs @ 350mA where the 3 watt runs @ 850mA. You can buy constant current electronic kits to run them and just make sure you put them on a heatsink to dissapate the heat. All in all these led's are blinding to look into but for their size and current output they should be in every RE's home or farm. I'm playing around with a 3 watt version and I reckon it would make a beaut spotlight for shooting. Then again with 5mm led's now outputting 20,000mcd and getting bigger running a few of them would be very economical as they only draw 20 mA each. If your interested I can put up a few basic circuits showing how to connect them.
Cheers Ruddy Crazy
« Last Edit: September 27, 2005, 05:19:37 PM by ruddycrazy »
« Reply #4 on: September 27, 2005, 08:48:13 PM »
what about a 250watt 13volt landing light[i  use it for testing my alts]
or a 28 volt 1000 watt landing light--that should light up your life..
just might take the spark out of it to! ;}........
« Last Edit: September 27, 2005, 08:48:13 PM by hiker »
crashk6
« Reply #5 on: September 27, 2005, 10:22:24 PM »
CACKLE
You just may be on to somthing ;~)
crashK6
« Last Edit: September 27, 2005, 10:22:24 PM by crashk6 »
« Reply #6 on: September 28, 2005, 12:41:20 PM »
If you're not worried about efficiency, then I guess the headlights are ok.  Compact Flourescents from our hosts are available at WWW.Wondermagnet.com.  A few of those in parallel would, I believe, be more efficient in terms of lumens per watt than the car lamps, or the Luxeon's. Another option are the 12V 40 watt flourescent ballasts.  Commercial versions are available, as well as several homebrew designs brought up  on this discussion board.  Rich
« Last Edit: September 28, 2005, 12:41:20 PM by richhagen »
« Reply #7 on: September 28, 2005, 02:22:42 PM »
I second this suggestion.
Car electric applications don't have to be efficient because there's SO much energy available when the engine is running.  What they have to be is inexpensive to manufacture, sturdy, and light weight.
Rule of thumb:  It takes four times as much power to make a given amount of light with an incandescent than with a fluorescent.
LEDs may beat fluorescents eventually.  Right now they're almost as hungry as incandescents.
« Last Edit: September 28, 2005, 02:22:42 PM by Ungrounded Lightning Rod »
Dreadstar
« Reply #8 on: September 28, 2005, 08:03:38 PM »
Pick up a 15" CFL it lights up the entire room and is adequate for reading for 18 watts 12vdc they have them here. www.nationalsolarsupply.com/index.asp?PageAction=VIEWPROD&ProdID=584
but there are of course other alternatives. car headlights are not the answer.
Home depot sells 110 volt mr16 bulb track light fixtures that can be modified to use 12 vdc mr16 bulbs if you like the really bright white light that hologens put out.
the mr16 bulbs come from 10 watts up to 65 watts that i have seen.
« Last Edit: September 28, 2005, 08:03:38 PM by Dreadstar »
4tap
« Reply #9 on: September 29, 2005, 11:56:19 PM »
  Jeez,  I thought i was the only  one that used headlights for lighting.  about 10 years ago when i got divorced i was living in a campground.  I put together one of those lawnmower engine- car alternator combos to charge 4 batteries in parallel to run a light and and a Homebrew inverter from an ARRL handbook. I used that system for a while then managed to get a house in the country.  Didn't have the cash for a power deposit so i kept the battery charger and inverter for a couple of years.  I rigged a solar water heater for hot water.  I got a solar panel surplus from the state, used it to charge the batts in good wheather,  Buy the time i remarried i was living well off grid.  New wife didn't like it so we moved ( bought a new house ) I still have the old one for a shop.  Now the engine runs off a methane digester with enough left over to run an old car on the gas.  My tractor is powered by producer gas from scrap wood.  Buy the way i just found the site and list today.  It's great.  I would like to have a small windmill.  I saw the ones on the home page. Fantastic  Keith.
« Last Edit: September 29, 2005, 11:56:19 PM by 4tap »
elvin1949
« Reply #10 on: September 30, 2005, 10:05:15 AM »
Keith
 How about a diary entry about your producer gas,
and methane gas production and storage and usage.
Several of us would be very interested in how you do it.
Elvin
« Last Edit: September 30, 2005, 10:05:15 AM by elvin1949 »
4tap
« Reply #11 on: October 01, 2005, 04:23:17 PM »
 Diary?  some new to read.  Cool. When i get a respectable camera i'll upload some shots.  I'll start keeping a log of the work site.  Keith
« Last Edit: October 01, 2005, 04:23:17 PM by 4tap »
DBGenerator
« Reply #12 on: October 04, 2005, 07:09:05 PM »
I looked through those web sites and couldn't find exactly what I was looking for.  I'll have to look again.
I bought my son an Eveready LED flashlight a while ago.  It uses 4 AA Batries.  It also has a fluorescent light.  He had it on all night in his tent for like 3 or 4 nights before the batteries ran out.  That's the kind of light I was looking for.
I'm kind of experimenting with my camper for solar and wind power.
« Last Edit: October 04, 2005, 07:09:05 PM by DBGenerator »
« Reply #13 on: October 05, 2005, 01:47:04 AM »
Holly methane!  Don't get a respectable camera.
Get a 'crappy' camera.
(Couldn't 'pass' that up)
The bad photos are less res so they upload / download easier.
« Last Edit: October 05, 2005, 01:47:04 AM by ghurd »
Parameter
« Reply #14 on: October 08, 2005, 07:07:52 PM »
I might look into 12v halogen lamps. Those come in 25 and 50w and much more, but the small ones are regularly used in kitchens and rail lamps. The lamps may be found in all good hardware store. They may be labelled 12 or not. It may really matter or not. You'll have to make some educated guesses there. Check some halogen lamp standards sites.
I have a lamp with a transfo at the base. I think it puts out 24v. I heard of some guy who took 100watts 220v lamps and run them at 120v for 50w... maybe that would make a 50w around 25 watts at 12v.... well, place for experiment.
I just bring this as halogen lights are really clean and better to read than fluorescents... tough on efficiency, the CFL win high-hand over the other stuff... even LEDs.
Have good experiments. You may just find an old halo lamp in the garbage and check the voltage. If it has a heavy base, it should have a transfo and lower than 120v bulb. If voltage is 12v or 24v, then identify lightbulb and start from there.
good luck
Para
« Last Edit: October 08, 2005, 07:07:52 PM by Parameter »
« Reply #15 on: October 24, 2005, 08:15:45 PM »
One use that car headlights may be good for is as diversion load, though I'd prefer to use water heating elements as diversion load.
I regularly use car headlights (12V/55W (5amp)) for testing power-supplies and smaller batteries (e.g. 7Ah). 2 weeks ago I converted an old PC powersupply from 12V to 13.8V (not very easy! involved disconnecting the +5V, re-wiring the stabilization loop (to +12V instead of +5), changing overvoltage protection, etc). Anyway, the PSU should be able to put out 13.8V at 10 amp. Just grab an old headlight (with the dimlight burned out), connect it, 5 amps! Connect another one, 10 amps! etc. One problem: it's difficult to read your DMM with all that blinding light X-)
So, my opinion, they're fine for PSU dummyloads and automobiles. For alternative energy, perhaps as diversion load, but not as main lighting, unless you've got more power than you can use (yeah, right...)
Grtz,
Peter
« Last Edit: October 24, 2005, 08:15:45 PM by dinges »
traviss76
« Reply #16 on: November 16, 2005, 03:41:19 PM »
I was pulling my hair out around here trying to figure out how to lower our electric bill it was 600.00.  So in searching for a way to convert to 12volt lights that was my mom's idea I went through a couple of adapters but they did not have the amp output for the 9004, 1157 automotive lights I was using so I looked around for anything that outputed 10 amps or more at 12volts and what did I find?  Well since you asked I'll tell you I found a COMPUTER POWER SUPPLY that oddly enough outputed +12v, -12v, +5v, -5v at varying amperage.  But the one I needed was +12v at 10amps.
I opened the unit and trimmed all excess wires and left the ground and the +12v and wired it to my lights and they worked and are still working.  I dropped the wattage from 400watts on my lighting to 85 watts with very little noticeability in candlepower.  I think we have another power supply in the shed on a busted computer so I will take it and use it for our internal lighting to replace the flourescent lamps and drop the watt draw from 200 watts to 60watts.  And we all know that that little spinning meter runs at watts per hours.  I figure if we get all 12volts appliances I'll just run them off my computers power supply.
I had to search for used parts I had here because we are broke.  But a new computer power supply is like @10.00.  Just get the 10amp output version at +12volts.
« Last Edit: November 16, 2005, 03:41:19 PM by traviss76 »
