Author Topic: board wierd behavior fix  (Read 316 times)
Arno
« on: January 18, 2005, 02:28:22 PM »
on all the posts down at the bottom are comments by. I click on a name, it comes on, then I click the back button. Click on the next name. It's fairly quick.   arno
« Last Edit: January 18, 2005, 02:28:22 PM by (unknown) »
Re: board wierd behavior fix
« Reply #1 on: January 18, 2005, 07:49:05 AM »
Arno;
Sorry, thats not a fix thats a "work around". Not to mention a major butt pain. Even then they still appear as unread  Thanks for the suggestion, tho.
T
« Last Edit: January 18, 2005, 07:49:05 AM by TomW »
JB
« Reply #2 on: January 18, 2005, 07:57:07 AM »
Ive noticed I have to be logged in to read the full story. I dont recall that before when I dumped the cookies. JB
« Last Edit: January 18, 2005, 07:57:07 AM by JB »
ADMIN
« Reply #3 on: January 18, 2005, 08:19:38 AM »
OK, I think i've tracked it down to how the new server is handling cookies. Will be digging into Apache ASAP to try and fix it.
ADMIN
« Last Edit: January 18, 2005, 08:19:38 AM by ADMIN »
meteorscatter
« Reply #4 on: January 18, 2005, 09:19:07 AM »
I'm back to normal, if your running Zone Alarm click on the ZA icon on your menu bar (righthand bottom of screen) then click on privacy. Look for Fieldlines.com check to see if session, persistent and third party cookies are X'ed out if they are then put the Green check mark where the X is.
This fixed the problem for me.
R/B
« Last Edit: January 18, 2005, 09:19:07 AM by meteorscatter »
meteorscatter
« Reply #5 on: January 18, 2005, 11:37:15 AM »
If your not running Zone Alarm,
This may or may not fix it for you.
First off I'm running Windows 98se and these instructions are for this OS.
OK, first log onto your start page, then before logging onto Fieldlines.com. go to your tools...(on the top bar of screen)....click and select Internet Options. Then set the slide bar to medium high, that's it! all done!
I can duplicate the wierd board problem by setting the slide bar to "High" or "Block all cookies". The ADMIN put me onto this when he mentioned how the server is handling cookies in another thread, so the credit goes to him.
meteorscatter.
« Last Edit: January 18, 2005, 11:37:15 AM by meteorscatter »
