"I dont agree about CCA thing. It may be true with most batteries, but i have a 'car-booster' power pack from Canadian tire that i charged when i bought, did about 35 boosts (its rated for 82 in a row or something) before charging, has been left numerously in the -35, and since bought (1 year exactly) has only been charged 4-5 times. "
I think your not looking at the battery for CCA with your booster your looking at the power it makes. Like using an inverter for 120Vac from 12vdc. It's not the same thing on both ends.
I have an everstart brand booster, hate it for a totally dead battery as it takes juice in the car battery for it to turn on. If the battery is totally dead then the unit will not work to start the car till you charge the cars battery. Real smart huh!
I trick it buy using jumper cables from a weak battery in the next car, unit turns on I remove cables and start the car from the booster, what a pain!
I had a Craftsman Booster, alot of them had problems, mine was great till one day it got to full charge and started a loud beeeeeppppp type constant noise and I had to exchange it even though it still worked great because the buzzer never shut off.
For an exchange since they did not sell that one anymore I got a free booster by Xantrex! It has a built in inverter, 12v power outlet, digital display, light, aircompresser all built into it Yee ha!
I was starting unused cars today with it for about an hour or more.
How one small battery can do all that I don't know, but for certain it's a deep cycle.
Anyway all 3 of those have a deep cycle battery to power them stuck inside the back.
CCA or booster power is from something inside being powered by the battery, maybe large transformer or something but it makes more power for starting the engine than just connecting cables to a battery would.
One of the 3 I mentioned was supposed to be around a 500 amp booster, I forget which one though. Probably means CCA as I can't see any way to get 500amps out of the little battery inside it myself. Maybe a 20amphr sealed lead acid?? Though the Everstart does say something about a specail type to produce high power and such, but still just a deep cycle anyway.
Whatever they are inside it's still just the same as connecting an inverter basically, just works different for starting. Yours is probably same way unless it's something totally different than any I have had.
